Question about Vizio VP322 32 in. Plasma TV
My vizio vp322hdtv10a, when prompted to turn on, turns on then off, turns on then off. This will go on for 2 minutes if I hold the power button until the unit will finally remain on
Would let me know about when power switch is turned on, it indicates no power. How do I start?
Posted on Oct 20, 2010
My kindle fire is frozen and won't turn off
Press and hold the power button for fifteen seconds or so, ignoring any "Shut down?" prompts, until it turns off. Release the button, then press and hold it for a second or two until it starts to reboot.
Sep 03, 2012 | Amazon Kindle 2
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
I have an VP322HDTV10A 32"
Take a look at the second half of this solution.
SOLUTION
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Televison & Video
I have a Canon Pixma MX 330 which I brought with me to the Philippines. A month prior to my departure, I used generic brand of black inks (210). A month after arrival, it started to prompt "error...
Please reset the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Dec 24, 2010 | Canon PIXMA MX330 Multifunction InkJet...
The tv is 2 years old. it would turn off after turning on by itself. this happened for 2 days. it would stay on afetr you turned it on a couple times. then the next day wouldnt turn on at all
Had the same issue with my Vizio Plasma VP322HDTV10A. At power up it would turn on and off a number of times before it would stay on. In thinking it might be the power cord, I pulled it out and replaced it with a spare I had and it would not power up what so ever. I opened up the case and traced the the internal power coord to it's source and this lead to the main power supply board. I found three capacitors on this board with buldges on them (which the tops of the capacitors should be flat). I found a web side (SHOPJIMMY.COM) which had the parts I needed to repair the TV myself. the following is how much it cost to replace the needed parts
LG EAY42539401 Power Supply
sj-EAY42539401
$ 67.16
Vizio VP322HDTV10A Cable Kit
$ 29.36
LOC: DA
Subtotal
$ 96.52
Also Included Photos of the board with the failed capacitors
Nov 28, 2010 | Vizio VW32L 32 in. LCD HDTV
My vizio vp322hdtv10a, when prompted to turn on, turns on then off, turns on then off. This will go on for 3 minutes if I hold the power button until the unit will finally remain on. It started out minor,...
Vizio has been plagued with problems because of cheap capacitors they used in their TV's. The culprit is CAPXON capacitors. As they go bad you will see a bulge on the top of the capacitors, once they totally fail your TV will not turn on at all. When you have time, open the back and inspect the capacitors, looking for the ones that have a bulge. You will need to replace these things, they cost about 50 cents each from places like Mouser electronics. Look for low impedance and same dimensions and capacitor value as the ones that are warping.
After having and fixing the same problem I will not buy vizio again. I would have preferred to just replace the whole power supply on mine, but I found out that you can't get boards unless you want to pay 100++ for used boards. So I just replaced the capacitors that were warping for about 1.50 plus 5.00 for S/H.
When you buy replacement caps, look for caps that are made in USA or Japan.
Aug 09, 2010 | Vizio VP322 32 in. Plasma TV
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Vizio VP322 32 in. Plasma TV Logo
503 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
