Question about Canon PIXMA MP180 All-In-One InkJet Printer
I need drivers to install my printer
As well as it says paper jammed all the time and there is no paper in it
    Genius:
  • 3,587 Answers
Www.canon.com has those..use support/drivers link.
as to the jam paper...turn off unit..let it sit for 20 min..try it again..
Posted on Jun 02, 2008
  • 45 Answers
Best place to download drivers is to go to your manufacturers website to get the best drivers.
As for the paperjam, there may be a piece of paper on the inside of the unit that you may not be able to see.
  • 44 Answers
We need to know what kind of printer it is
4 Suggested Answers
SOURCE: i have a ip4200 paper jam error - there is no paper jam
Try spraying the printer out with a can of airdust
Posted on Dec 21, 2007
Suricatta
  • 92 Answers
SOURCE: paper jammed but no paper is jammed.
I guess there is a small piece of paper near A4 sensor...
Try carefully to dismantle and clean...
Good luck
Best Regards
Posted on Jun 26, 2009
SOURCE: Its saying paper jam and its no paper in the
check front and rear paper sensors. Maybe they damaged. Clean optical sensors.
Posted on Sep 30, 2009
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
Paper jam indication on laptop but printer works
In order to resolve the issue, you need to have either the Printer Driver CD or the installation file that you can download from HP Website.(Make sure you download the full feature)
Delete the printer icon from Printers folder.
And Run the CD/Driver File.
Select the option of Add a device from the list.
And let the installation complete.
If the issue still persists, please post on it for further steps.
Apr 27, 2010 | HP PSC 1215 All-In-One InkJet Printer
Error paper jam
You should go to the website of whoever manufactures your printer. They always have drivers for their printers that you should be able to download and install in just a few minutes.
If you're absolutely, 100% sure that there is no paper jam, I would recommend just unplugging and restarting the printer.
Also, it may read a paper jam if you insert too much paper at one time. If you have a lot of paper installed in the printer, try taking out all but 10 sheets, and retry printing. My printer has a tray that accepts 150 sheets, but it "jams" if you put even close to that many in.
You should make sure that you aren't putting the paper too far in as well. Try pulling it back a few millimeters, as it may read a jam if the paper is pushed into the printing area.
Jun 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer jam
there are 2 possibilities, it is either the printer has small bits of paper on the rollers in the printer, or the printer drivers needs an update to make it run again.
you may open the printer up, inspect the rollers (paper path, where the paper goes in and out) then check if the rollers rubber coatings are worn out or damage, or has pieces or papers on them.
in installing the drivers, just access the HP's download site and download the latest drivers for your printer.
Nov 05, 2008 | HP Officejet 4315v All-In-One InkJet...
Paper jams every time I try to print something
2 possible solutions.
1 The paper itself. Check that the paper tray is not overfull. this can cause multiple sheets to feed through. Also make sure that you use good quality paper suitable for the particular type of printer. Always keep the paper dry Damp (not wet) paper will also cause the sort of problem you describe. another good reason for not keeping to much paper in the paper tray. Paper will keep better in the packet than in the tray. Always store the paper in the packet in a warm dry place. I keep mine near a radiator and away from the Air con.
2. The printer driver. Download the latest driver for your printer from the manufacturer and update the printer driver, via the control panel/printers. If you don't know how to do this you can simply uninstall the printer and then install it again using the new printer driver.
Good Luck
Carrieone
Jul 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
Need help with printer dell 942 paper jam
Power off the Printer
Un Install the Drivers of the printer
restart the system
re-install the drivers
if the problem continues
1. check the printer data connector
2. Check the correct paper is loaded
3. Check the colou catridge status
Feb 16, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
First when you see that first page come out like that...turn the printer off. You will need to re-install the printers drivers. (the CD that came with the printer)
Sep 20, 2007 | HP DeskJet 920c InkJet Printer
Problems with scanning and printing
You have a very tiny paper jam that you have missed. You need to use a torch and tweezers and get right inside and look thoroughly and down behind in paper feed area. You will find a very small piece of paper somewhere broken off and jammed or a foreign object. Your scanning problem could be corrupted driver. Go to manufacturers site and download updated driver for your model. Uninstall printer completely before reinstalling new driver. Good luck
Aug 25, 2007 | Compaq A3000 All-In-One InkJet Printer
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
old marine
old marine
