Question about HP LaserJet M1005 Printer
My printer m1005mfp display scanner error 20 on switching on
  • HP Master
  • 7,733 Answers
Scanner Init error!!
some solution ? i have the same problem :(
Jul 10, 2012 | Oki Electric Industry Oki MC560N...
Hp 1005 Scanner error 20 please suggest the problem
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it. Plug the device directly into the wall socket.
Use thepower switch to turn the device on.
Jul 08, 2011 | HP LaserJet M1005 Printer
Hp laserjet m1005mfp scanner error 20
Hi there and welcome to Fixya!
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the device on.
This error message is usually fatal so if the problem persists after trying the steps above, you will need to contact the manufacturer for further assistance. Please refer to the manual that came with the printer for contact information.
Thanks!
Jul 02, 2011 | HP LaserJet M1005 Printer
Printer not activated, error code - 20
You may face the "Error code-20′ with your printer installed in your Windows 7. The cause of the display of "Error code-20′ may be due to the following reasons. The desired printer may not be the default printer for your prints, issues with the USB composite device, and file missing or file corruption with the printer software supplied by your original equipment manufacturer.
Jan 03, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner does not work. 12 scanner error on the display
scanner does not work. 12 scanner error on the display
Jun 25, 2010 | HP LaserJet M1005 Printer
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
My scanner error message
Whatever the error message you get, write it down and Google it, you will always find the solution. It has never failed for me. But be carefull some solutions could end up costing you.
Oct 22, 2009 | Office Equipment & Supplies
Scanner error 20
your scanunit's lamps frecuenci is changed you should replace the scanunit
Jun 20, 2009 | HP LaserJet M1005 All-In-One Printer
Error code A7 on brother mfc-420cn
Hi there
(A7 One-line feeding timeout error. )
Brother Error Codes RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 05, 2009 | Brother MFC 420CN All-In-One InkJet...
HP LaserJet M1005 Printer Logo
675 people viewed this question
Seeker5211
Seeker5211
