Question about Exercise & Fitness
How to reset ee error list init on star trac elite treadmill
3 Suggested Answers
SOURCE: StarTrac Pro Treadmill startup error (ee error
Posted on Jul 05, 2010
  • 1196 Answers
SOURCE: how do i reset ee error list init on startrac pro
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful.
Posted on Sep 22, 2011
Fault on treadmill saying E1 been told its batteries were are they situated on machine
Here is a link to the manual. http://gymstore.info/manuals/upload/Star%20Trac/star_trac_7600_pro_om.pdf
You might want to try the troubleshooting procedures on pg 47.
States if error code appears, "Call your dealer or Star Trac at (800) 503-1221, or USA 1-714-669-1660 for service."
Mar 02, 2015 | Startrac Fitness Products Star Trac Pro S...
Tip
How to Change a Star Trac 4000 Treadmill Running Belt and Deck
This video will visually assist you in the procedure of changing the deck and belt on a Star Trac 4000 treadmill.
Star Trac Unisen Treadmill TR4000 Parts SPORTSMITH net
on May 15, 2014 | Startrac Fitness Products Exercise &...
Trac Star 4500 trouble Code EL STL
The error code by definition is listed in section 3 of the service manual.
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20TR4500.pdf
Dec 08, 2013 | Startrac Fitness Products Star Trac 4500...
Ee error list init
It' s full sheet .You can start with reloading the software with Fisps
You will need to Load Primary 8.10 and Secondary 3.30
Software and instructions can be found at:
http://support.startrac.com/index.cfm?fuseaction=software.Software
If this does not work it will require a complete new display electronics:
http://support.startrac.com/index.cfm?fuseaction=diagrams.Dia02b&typ=1&sty=1&srs=11&mdl=28&prd=1028&stc=1033&sku=9-7632-SUSAP0&dia=624&dlk=&wsr=&sid=
715-3604
May 09, 2013 | Startrac Fitness Products Star Trac Pro S...
I have star trac elite it have fuse bits failed problem I also change the fuse it still have fuse bits failed problem
Then you have a short. Will need to track down the source of the short and fix it before the fuses stop popping.
Apr 11, 2013 | Startrac Fitness Products Star Trac Pro S...
Star Trac 4500 el r n g
All the error codes can be found in the service manual in section 3.
Jan 21, 2013 | Startrac Fitness Products Star Trac 4500...
Star trac 3901 no rpm
A complete description along with a solution can be found at the following link.
NO RPM Error and Why it Displays on StarTrac treadmill
Jan 21, 2013 | Startrac Fitness Products Star Trac 3900...
I have star trac pro treadmill,when i shifted from another place it show the error
1) Run the software calibration for diagnose, troubleshooting.
2) However adjust the reed switch, clean, and tight any wires connector see the diagram
3) adjust the speed sensor, clean, and tigh the wires connector see the diagram attached.
Jul 06, 2012 | Startrac Fitness Products Star Trac Pro S...
Error code EL 2 ?
EL 2 Error code means an erratic reading coming from the elevation potentiometer. Unfortunately that means a replacement of the motor Star Trac does not sell just that one part. But you maybe able to send the motor to be repair for aabuot 1/2 cost of a new one. Call this # 1800-496-7278 conpany's name is Nation Gym parts they can help you
Jan 19, 2010 | Startrac Fitness Products Star Trac 3900...
Exercise & Fitness Logo
281 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
