The TV does not turn on. the stanby light remains on wheter i switch the TV button or the remote. Can this be fixed. as the TV is out of warranty.
  • 998 Answers
Yes it can be fix its only the power supply try too look for swollen capacitor then replace it.
Posted on Oct 15, 2010
CANT PROGAM UNIVERSAL REMOTE TO TV
From http://www.ehow.com/how_7158721_connect-remote-tv.html :
  • 1
  • Hold down the program button on the remote control for 3 seconds. This button mighty be displayed on the remote as "PRG." When you have done this, the LED light on the remote control will turn on. The light will remain on for the remainder of the programing process.
  • 2
    Press the "TV" button on the remote control to let the remote know it will be syncing with a TV. Universal remotes have multiple device buttons that let you connect other devices, such as the VCR and DVD player, to the remote. Having the TV properly programed under the "TV" button makes it much easier to switch back and forth from another device to the TV.
  • 3
  • Find the proper codes for the TV you are programing. You will find a link with a list of TV codes in the Resources section below. Input the 3-digit code into the remote and press "Enter." If the code took, the light will turn off and the TV will turn on after pressing the "Power" button. If the light remains on, stand closer to the TV and move any objects that are blocking the signal from the remote to the TV, then start the programing process from Step 1 and continue down the list of codes until it works
    Resources:
    TV Codes: Universal TV Remote Control Codes
    Hope This Helps!
    -Be Sure To Rate MacAppleZoo 100% Or Whatever You Think I Deserve!-
    Sep 12, 2011 | Televison & Video
    Our new led tv turns itself on in the middle of the night and shows a rectangle of light in center of screen which says" no signal"and something about power??????
    Remove set off power , make sure that the power is activated and is switched off with the remote. This can be some residual voltage and if the resetting does not bring about a change , I RECOMMEND that being a NEW TV you must take the free WARRANTY CLAIM before this set is tampered.
    Aug 11, 2011 | Samsung Televison & Video
    Hi, how do i sync my venom dvd remote to my xbox 360? thank you
    To enter a TV code:
    1 Turn on your TV and point the remote toward it.
    2 Press and hold the TV and OK buttons simultaneously for two seconds. All of the buttons on the media remote will then light up for two seconds, after which only the numeric TV buttons (1-12) will remain lit.
    3 Enter the code for your TV.
    4 Press the TV button again to save the code and exit. All of the buttons on the media remote will blink three times to confirm your selection.
    To scan for a TV code:
    on the media remote will then light for two seconds, after which only the numeric TV buttons (1-12) will remain lit.
    3 Press the CH+ or CH- button to send a series of off commands to your TV. Repeat until the TV turns off.
    Jul 02, 2011 | Venom DVD Remote Control for Xbox 360
    My samsung 32 inch turns on goes to white snow screen but I get no volume the buttons don't work and I tried a universal remote and yet nothing seems too work. Help me please.
    moa
    replace caps in psu panel and eprom or try factory reset switch tv to standby then mune mute info stanby buttin on remote if you get service mune try reset.
    Aug 17, 2010 | Televison & Video
    I purchased a JVC LT52X579 March 30/09. The TV would phase out by itself and then restart by itself. Some times it would remain on and could be cut off only by unplugging it from my sudge protection...
    Please unplug TV from wall socket for couple of minutes, replug back in and turn ON.
    If still does not power up, try it in another wall socket.
    Also check standby/ power light flashing or its solid at TV.
    If standby light is flashing or its not lit then TV got power supply problem and requires qualified TV tech. I hope TV is still under warranty so ask for warranty cover to store.
    Thanks.
    Jul 24, 2009 | JVC Televison & Video
    My sony TV wont turn on.
    Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
    Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
    Can't turn on from Stanby mode
    I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
    Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
    10blinking model KVHX32M31
    You should contact an authorised Sony repairer as they have a fix which took abot half an hour to solder in a replacement part which had been damaged by over-heating. Ours was fixed under extended warranty.
    Oct 22, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
    This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
    Thanks,
    Dan
    Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    Hyundai 42" Plasma TV
    Try www.hyundai-world.com That is the manufacturers website. Good luck. Ask them if that set can played in the USA without a special power supply.
    Nov 19, 2007 | Hyundai HPT-4250 Television
    Televison & Video Logo
    50 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
