Vaillant atmomag mini 11 -0/01B p roblem with initial firing no gas passing through gas valve though sparking O.K
  • Anonymous Mar 23, 2014
    heater does not pass from 30? and water is not hot
  • 20 Answers
Be sure you are pressing down on the pilot button.
Posted on Oct 15, 2010
Intermittent hot water.Changed diverter valve,heat exchanger,fan, PCB. Vaillant turbomax 282e But still no hot water.
Sounds like you need a new Thermo coupler.
Could be as simple as a dirty pilot and needs cleaning but I suspect a thermo coupler.
Apr 14, 2016 | Water Water Heaters
Will not crank
Buy a new spark plug. If you have gas and it appears to have spark replace the plug. What happens very often with small 2 stroke engines is that the spark plugs coke with carbon and will test fine with the plug removed but when you re-install the plug no matter what you do it will NOT start.
Stay away from the mini Champion spark plugs. Recently their failure rate is substantially high. Even the new ones will only last about 20 minutes. I have found that the Bosch plugs are very reliable for this application.
If it still does not fire after replacing the spark plug resond here and there is more that I can pass on to try and get you going again.
Thanks for using FixYa.
Kelly
May 21, 2010 | Husqvarna 28cc Gas Line Trimmer
Its a vaillant condensing gas boiler, it is showing problem with ignition, it won't fire up. fault code 28
f:28
air in gas
gas rate low
could be gas valve faulty,ignition transformer,ignition cable.
if there is a spark then its your gas valve,if no spark then check continuity on harness and spark generator,also check earth to appliance
Oct 19, 2009 | KDS Valiant 6380iPTD-01 Notebook
How do I light pilot on Vaillant boiler
turn and push in button on your honeywell gas valve hold it in and spark lighter cont to hold for 20secs then ease finger off button very slowly pilot sould stay alight if not try again in 2mins best of l;uck
Sep 29, 2009 | Water Heaters
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
The electric spark lights the gas at the spark area but the rest of the oven flame never materializes and the spark continues to click even though the initial flame is there
Make sure the thermocouple from the gas valve is in the pilot flame. If it is and you have no ignition,replace the gas valve. The clicking stops once the oven ignites.
Aug 24, 2009 | Roper FGP215KQ Gas Kitchen Range
Heating & Cooling Logo
637 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
