Question about Kyocera Copystar CS-5035 Copier
Kyocera 3035 Everytime my Kyocera 3035 copier prints or copies anything there is a black line across the middle of the paper. What do I need to do to fix it?
  • 29 Answers
If ti is a print from machine memory and not from glass the charge is durty the remove charge unit aboth drum and see if there is not durt on the charge wire or on the grid wires the green charge cleaner aboth the wast toner may also have come of and now staning on the rong place , if that is right your laser **** glass behide the drum may be durty if its a copy the small glass onther the document feeder is durty some copiers have a document feederthat have a scanner on the inside oppen the feeder lift the green lever and you fined a small glassin there that need cleaning and last o yes and last do this first open your left side door look at the drum if there a line on the same place than on the paper the drum blade does not clean it and a peace of paper may be stuck betweenblade and drum
Posted on Aug 07, 2012
Is the line appearing after the drum? After the fuser? when the original is laid on the glass to copy or fed through the document feeded? What kind of line? How wide?
Posted on Jul 06, 2008
  • 22 Answers
START COPYING AND OPEN THE FRONT DOOR IN MID-CYCLE. OBSERVE JAMS. TRY A FEW TIMES. THEN YOU'LL SEE AT WHAT LOCATION OR ROLLER, THE LINE IS OCCURRING. SEE IF THE LINE ALSO APPEARS ON THE DRUM.
THE 3035/4035/5035 IS THE BEST COPIER EVER DESIGNED.
Posted on Jun 24, 2008
    New Friend:
  • 48 Answers
Stupid question but make sure that there is nothing on the glass surface underneath your document feeder. Be sure to get the main glass clean as well as the little strip of glass to the left. If this didn't fix your problem than you need to do a little more cleaning.
When was the last time you changed the toner? In the toner box you should have gotten a small grayish blue box with a plastic top and felt head. There should have been instructions on how to use this little cleaning tool but what you need to do is to remove the waste toner bottle being very careful not to spill the waste toner all over yourself. Before you do anything else you should gently take out the green square handle. Now behind the space where the waste toner bottle is located you will notice a small hole that fits the little blue box minus the cap. Gently place the blue box (peg first) into the hole (should only fit one way but the felt tip should point to the right) and gently move the green handle back and forth 3 to 4 times. Take the blue box out and throw away, put the green handle back in and than replace the waste toner bottle.
If you don't have the little blue box than call the company you got your copier from, they should be able to help you.
Hope this helps.
Henry
Posted on Jun 03, 2008
WHITE LINE THRU PRINT ON KYOCERA MITA KM-3035
clean the LASER glass for that color, if you dont know what that is get a tech out.
Jan 22, 2016 | Kyocera Mita KM-3035 All-In-One Laser...
My kyocera 3035 print out nothing but black paper. what's hapng??
nesesitas give more information, but the problem is in the main charge corona,
replaces the charging wire crown,
Feb 24, 2015 | Kyocera Km-3035 Copier, Print,scan,fax ,...
My copy is black
my photocopier km 3035 black print problem
Aug 09, 2012 | Kyocera Mita KM-3035 All-In-One Laser...
How do i fix a line coming thru all my prints and copies
If you have to ask "how", you should not even *TRY* to fix it -- instead, contact the local Kyocera office, and book a service-call by a qualified technician.
Apr 05, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Km-3035 Locked in cardstock
press default setting/counter button
press bypass setting
press paper type
Apr 03, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Printing LABELS...print out is not centered
there are paper guides on either side of the paper in the bypass... make sure thy are nice and snug right next to the paper...
Mar 26, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Print out landscape
Make cassette number 1 8 X 11. Load paper portrait in tray 1
Mar 08, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Cannon Imageclass printing problem
You need to check your glass first to make sure it has no scratches. Then you can run a copy and open door to stop paper in the center of the machine, b4 it goes through fuser. If line is on copy, you have a bad drum. If not your upper fuser roller is bad.
Oct 19, 2007 | Office Equipment & Supplies
Kyocera Copystar CS-5035 Copier Logo
303 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
