Does anyone know where I can buy a replacement wired volume control for my 5.1 PC sound system? The cat has chewed it and I have to twist it round and wedge it to work....
  • 62 Answers
Yes it can be found any of the computer shop........if not then contact the manufacture.........they will definetly help you.....check user manual for contact
Posted on Oct 15, 2010
Cable for phillips subwofer computer system not working. Is there a replacement i can buy
switch on the speaker system remove the jack connected to your pc.give full volume / off volume,
just touch the jack pin from your finger.check the sound is coming.
if sounds well your speaker is ok.problem with pc.
if not in woffer ic has to be replaced.
Nov 07, 2013 | Philips MMS171 Computer Speakers
Do I need to buy a chew toy for my new cat?
That's agood question. I have seen chewing toys available at cat shops but in generalcats are more into scratching than chewing. Kittens might enjoy a chew toy butit really depends on the cat. Don't spend a lot on those kind of toys unlessyou see that your cat is really into chewing.
Jul 24, 2012 | Cats
My dog chewed up cord. How do I repalce Milwaukee Model 6507 Sawzall
this should be a twist lock cord and all you need to do it twist the connector at the handle area and pull the cord off and buy a replacement, make sure whether it it grounded (3 wire) or double insulated (2 wire), you can go to Milwaukeetools.com and with your serial number look at a schematic for this tool and they also have a dealer locator to ensure that you get the proper one. Let me know if you need more assistance.
Sep 19, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
A cat chewed throught the wire do anyone have a effective way to fix the cable on a note i thaught about brushing off the insulation with a wire weel or just soldering the wire togheter
One method is to bare the ends of the individual wires, and lay the cables side by side.
Don't worry about uneven lengths, just as long as you can get the appropriate wires together.
Solder or even twist them together, and tape each connection to prevent them shorting out.
Heatshrink tube is great here if you have any. It males a tidier repair.
Now tape together the paired cables for about an inch, then lay out the cable so it is straight and bend up the join to lay along it and tape it there.
This prevents strain on the joins.
I don't know about a wire wheel, it might not be delicate enough for this application, but thank you, I'll remember it and try it sometime.
Jan 29, 2011 | Sennheiser PMX 60 Consumer Headphones
My home theater receiver totally shuts off when the sound level is turned up above 2
bad speaker polairity or crossed wires
cats like chewing wires so do pupys
and a lot of other small vermin like wires too rats mice dogs cats
check your wires then check the polairity failing that check unit 4 over heat
to check wires disconect 1 speaker at a time turn on reciever and turn it up
failing that check unit for in operational fan in rear of case
Jul 31, 2009 | Audio Players & Recorders
My cat chewed the wiring on my Bose in-ear headphones
Of course. Just peal off the main isolation and connect wires according to color of their individual isolation. You can just twist them and wrap them with duct tape or solder them and wrap with duct tape.
My cat recently chewed trough 220 Volts stereo power cord (fortunately unplugged) and trough speakers cable too. They work perfectly again after quick fix while my room has become off-limit zone to my cat. ;-)
Better get your tomcat fixed or find him a girlfriend unless you'd like to risk him getting killed when he starts chewing some power cord.
May 10, 2008 | Bose in-ear headphones - Black with...
Cut Cord
Please specify. What did the cat chew the wire to?
Jun 20, 2017 | Logitech Premium Headset
Multimedia speakers not playing up to potential
After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the excellent solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows: <p> 1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.<br>
2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it.<br> 3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up..<br> 4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only. Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.<br>
5. Put the FR speaker box back together in reversed order.<br> 6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again.<br>
<p> As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.<p>Thanks for giving the lead trickytrev34.
Jun 27, 2007 | Altec Lansing Multimedia Computer Speakers
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
