Question about Dynojet Cycling
Hi,just got a dynojet stage 1/3 kit for my 1980 honda cb650, it's on standard air box, but 4 into 1 exhaust, I take it I should use the stage one kit. Also I have no instructions can you help please.......................................cheers......paul
    Novelist:
  • 108 Answers
Intended for motorcycles with a stock engine using the stock airbox, air filter and stock pipe. Stage 1 kits are fully adjustable to allow the use of a well designed aftermarket pipes and stock replacement air filters like K&N. Stage 1 kits are designed to improve throttle response and driveability and in most cases power increases of approximately 5% throughout the entire power range can be achieved.
STAGE ONE INSTRUCTIONS
1. Remove the vacuum slide from the carbs. Remove the stock needles & spacers, noting the order of
assembly. Locate the slide lift holes (Fig. A), with the slide drill DD# 14 supplied, enlarge your slide lift
holes. The picture may not show your slide exactly, enlarge your slide lift hole or holes depending on your
model. Do not drill any new lift holes. Do not drill the needle hole.
2. Install Dynojet needles on groove #4, using all stock spacers. Install the Dynojet washers (2 per
needle) above the E-clip.
3. Remove the stock main jets and replace with the Dynojet main jets provided. If you are running with
stock exhaust, use the DJ110 main jets. With an aftermarket header or slip-on with high flowing baffles,
use the DJ116 main jets. Be sure that the jets you are changing are the main jets.
4. Locate the fuel mixture plug (Fig. B), if you see a screw head, proceed to adjusting procedure. With the
DD #5/32 drill bit provided, carefully drill thru the plugs. Note: the mixture screw is directly underneath this
plug, be ready to pull back on the drill the instant you break thru. Use screw provided to secure and
remove the plug. Carefully turn mixture screws clockwise until they seat, turn out 3 turns.
For further info on this, visit: http://www.dynojet.com/jetkits/motorcycle/honda.aspx
You can find the manual for the model you are searching for. Follow the 1st column "CC" to find 650cc models and you can find your specific model after that.
Thanks for asking.
Regards,
Arvind S Iyer
Posted on Oct 15, 2010
I took off air box added airpods with stock exhaust on a 1981 suzuki gs 650 what size main jets should i replace with
Richard, I would suggest you go with a stage 3 jet kit for improved air flow. Ebay has them for a great deal. I'll post a link. Good luck. ^^
Dynojet Stage 3 Jet Kit For Suzuki GS650 GS 650 1981 1982
Aug 18, 2015 | Suzuki Motorcycles
1988 Honda CBR 600 F Hurricane assorted carburetor jets
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Carburetors Parts for Honda CBR600F eBay
Dynojet Carburetor Jet Kit Honda 1987 1989 CBR600F 1122 Stage 1 2 eBay
Honda CBR600F4I 2001 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F Owner Manual
Dec 08, 2013 | 1988 Honda CBR 600 F Hurricane
Marauder carb
Try new plugs
Sep 01, 2013 | Motorcycles
1985 Honda CB 650 carburetor tuning for air pods
Hi, Jack if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" you're not getting enough fuel.
1. Close to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. Wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, the engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
1980 CB650 Carb tuning
Pod filters and Carb Jetting
Honda 1998 CB600Fw Shop Manual
Honda cb650 Owner Manual
Apr 27, 2013 | Honda Motorcycles
How many jets are in a 1999 vz800 marauder
If you bought the kit for the bike everything should be there to complete the job with instructions.
Aug 28, 2012 | 1999 Suzuki VZ 800 Marauder
I have 175 and 180 size jets in my carburetor on my 04 Sabre. Are these stock? My Dynojet stage 1 kit has 160, 165, 170, & 175...which are smaller...
It doesnt matter if the jets are stock or not it is a myth that the jets must be bigger when you put a stage one kit in. Remember stock jets are there for EPA standards and what size works to pass is what the manufactor will use. I have many times put smaller jets in a carb even on race bikes to get a better performance. I hope this helps.
Nov 03, 2010 | 2004 Honda VT 1100 C2 Shadow Sabre
What size dynojet main jets are required for honda cbr 600 91-94 in the UK bike fitted with K n N filter and viper end can , and how many turns out on fuel mixture screw. ( lost my instructions) thanks,...
HI A DYNOJET KIT INCLUDES MORE THAN JUST MAIN JETS, AIR CORRECTORS, SLIDE NEEDLES, AND IN SOME CASES NEW SLIDE SPRINGS ARE INCLUDED, SLIDE LIFT HOLES ARE ALSO DRILLED OUT TO GIVE QUICKER THROTTLE RESPONSE, AS DAFT AS IT MAY SEEM YOU NEW MAIN JETS IN MOST CASES WILL BE SMALLER THAN THE ORIGINAL JETS, IF YOU ARE THINKING YOUR BIKE HAS BEEN DYNOJETED BUT ARE NOT SURE CONTACK DYNOJET UK FOR HELP, HOPE THIS IS OF USE FOR YOU,
http://www.dynojet.co.uk/jetkits/index.htm
Oct 27, 2010 | Honda Cb 400 F Motorcycles
Which way do i move the needle to weaked the mixture on a dynojet kit fitted to honda cbx1000z
Most jets work in a clockwise motion .clockwise weakens ,anti clockwise richens .but be carefull too little fuel may cause pinking or piston rattle .
Mar 14, 2010 | 1980 Honda CBX
97 srad no power under 4000 rpm in, in first gear acceleration
If you have installed the Dynojet kit's carburetor needles take them off and use the stock ones.
Dynojet's needles are for track use only and the don't work properly under 4000rpm.
Jun 15, 2009 | 1999 Suzuki GSX-R 600
Cycling Logo
332 people viewed this question
Top Dynojet Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Dynojet Cycling Expert? Answer questions, earn points and help others
