Question about Pioneer SD-P50A5-K 50" Rear Projection Television
HI I HAVE A SPIDER WEB IN MY TV HOW CAN I GET RID OF IT . IT REALLY BOTHERS ME WHEN I WATCH TV BECAUSE I CAN SEE IT
  • Pioneer Master
  • 5,138 Answers
Remove back and use a long handle duster to dust out cobb webs,or remove front screen and clean Mirror and top of Tube lenses as well as the cob webs.Pull Front bottom panel off, then remove screws holding Top Sceern on ,it slides up and then out.
Posted on Oct 15, 2010
  • 998 Answers
Try to open the back of your tv but be sure to unplug it then clean the projector lens using a dry cloth cotton.
Bought my tissot watch on 23 rd May. As I am new so I am really confused because the date is changing at 12 :30 am instead of 12 am. The model is T033210 A. Is it faulty ?
I see this is a Tissot 1853 watch. As you bought it very recently, I would expect a good quality watch like yours to change date soon after midnight. However, it's probably not faulty. There are many watches that don't show the correct date until as late as about 2 am. If it really bothers you, the you would need to get the hands reseated so that the watch shows midnight when the date change occurs. This is not an easy job, and best left to a professional. My advice would be to ignore it if the watch is otherwise performing OK.
May 25, 2016 | Tissot Watches
Spider nest behind the dash clear plastic face. My wife is freaking out and is worried they will hatch and come out from underneath. Help
If there is a spider nest in the car you can simply use insecticide spray to spray the spider nest that will get rid of them,you can also spray the nest with air freshener that also will get rid of the spiders.
Aug 15, 2010 | 2000 Mazda MX-5 Miata
Hi I have a Sony KDP-57XBR2 and my problem is that when the tv is on, there are horizontal white lines that you can mainly see when the picture is dark. It really bothers me when watching a movie or...
adjust the screen drive controls up for your TUBEs R/G/B you have a focus/screen control block that adjusts Each Tube itis in front of TV remove bottom panel and it will be there.
Jan 02, 2010 | Sony Grand WEGA KDP-57XBR2 57" Rear...
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Broken Screen
screens cost about 1000 and up - usually not worth replacing
Feb 25, 2009 | Philips 52 In. LCD HDTV
Possible spider web inside of reprojection Tv
Yyou can clean screen's internal side by takeing off back cover of tv. Belo is picture how to open back cover.
Sep 24, 2008 | Sony KP-46WT500 46" Rear Projection...
Vertical red line in display
I had a similar problem with a flat screen lcd for my desktop comp, and it turned out that I needed a new screen if i wanted to get rid of it, but it doesnt really cause much of a problem, so i didnt bother replacing it. If your laptop is still under warranty, (i dont know how long your warranty lasts) I'd look into getting it replaced if it really bothers you. But yes, its definitly the screen.
Aug 08, 2008 | Dell Latitude D505 Notebook
Moving Bars On Screen...
There is a large capacitor in the power supply section. it is rated at 820uf @ 200vdc. It is bad. Change it and increase the voltage rating to at least 250vdc. The tv will be fine.
Jun 21, 2008 | Apex Digital PF3230 32" TV
MY WD-52327 has a small area (approx 1"-1") toward the top right hand corner of the screen that appears to be cloudy. It's gray and really only appears against lighter pictures. Any thoughts?
I had the same issue with mine in different areas of the screen. Really got to me one night while trying to watch a movie. I ended up taking the screen off the front and found numerous dust bunnies on the mirrors and a spider web in one of the corners. Cleaned up and blew out with canned air. Was crystal clear again with no spots.
Mar 09, 2008 | Mitsubishi Televison & Video
Projector Image Problem
Hi There
Your Projector switches to a 16:9 ratio when hooked up to a Video signal and to a 4:3 Ration when hooked up to a PC signal.
You can manually change this in the Menu functions if this bothers you.
Simply go to Aspect Ratio in your Menu's subfolders and press left or right once you scrolled down to it.
Sep 21, 2007 | BenQ MP610 Multimedia Projector
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
90 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
