Question about Sony Bravia KDL-32ML130 32 in. LCD TV
I just turned my sony bravia back on after it being off for around a day and now the picture is very red and dark. Also it looks like I am seeing many frames at once(kinda like a bad web cam) whenever things are moving on screen. Can anyone help?
  • Noel Jucutan
    Noel Jucutan Oct 15, 2010
    try to adjust the picture mode in your remote.go to quick menu and select picture mode.
  • natefrog80 Oct 18, 2010
    I hadn't been back to check this in a while because it fixed itself for a little bit but now its back. I can change the color, but it never looks normal, but I always have the problem of there being shadow frames whenever there is motion on the screen.
  • 998 Answers
Try to check the all the connection of your tv, specially the aerial connection.
Posted on Oct 18, 2010
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony Brovia TV the picture went dark. You can see it but not to well.
Picture Become dark means there is some problem with the back light of the tv. can be problem with the back light led drive or the led array.
www.electro-medical.blogspot.com
Sep 06, 2015 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
KDL-40EX720, 4 blinks on a Sony Bravia
try making sure that the picture plug in the back of the television is completely plugged in.
Mar 10, 2013 | Televison & Video
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Our Sony Bravia tv picture keeps going light dark light dark. What is causing this problem? It is very annoying when it goes dark because you can't see the picture. Please help.
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
Oct 16, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Slow picture and dark reddish tint
These sounds like you have an issue with main board or tcon. Picture slow makes me think this is a communication issue between the tcon and the main board.... This needs a professional diagnostic. The good news is i don't think it is the panel which would make the cost of repair beyond the cost of the tv. If it is in warranty or just out of warranty call sony, sometimes if it is just out of sony's 1 year warranty they will make exceptions. But you need to call them for this exception.
Some solutions are not cut and dried and an on-site diagnostic is best. In your case this is true. I have worked on sony for many years and that symptom (at least the way it is described) is not one I have seen.
Oct 10, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Sony Bravia KLV-32U300A 32 in. HDTV-Ready LCD TV just lost the picture. Just see different colors. Hears static sound from the back of the unit. This was a progression. Few days ago, clicking sound...
hi..It's probably a loose cable. The first one to check is the
green connection but make sure they're all tight. RCA cables
tend to pop out part way which is enough to stop the signal.
If the green signal is lost, you get no picture. If the red or blue
are lost, you get a picture with bad coloring.
If you still have the problem check this
LOOK in the back of the TV when you have it turned on. Look in the slots near the top for a white glow coming out of it.
IF you see it, you need your signal board replaced...
IF NOT, then you need your power supply board replaced...
Apr 19, 2009 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia
It sounds like the backlight is going bad or possibly the panel. Let me see a picture of it. Talk to you later. Jay
Feb 01, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-32ML130 32 in. LCD TV Logo
312 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
