FixYa.com
Tags:
Copiers
Generic problem for all Copiers
Konica Minolta magicolor 5570 Empty Toner Message
posted by Arrlan on Jun 02, 2008
Hey, recently the cyan ran out on our 5570 (which is odd because the M and Y are at 50%), we replaced it with an official new Konica Minolta toner cartage, but it still says cyan is empty and won't let us print. I checked the maintenance menu, but there isn't a reset supplies option for toner. I tried the obvious solutions (replacing the cartrage, turning it off for a few minutes etc).
Last time i called their tech support, they had a maintenance guy out here 2 or 3 times before it got fixed, so i'd love it if there was some way to fix this without calling them again! Any ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
This Problem Also Relates To: HP 290 Color Copier HP 280 Copier Panasonic DP-8035 Grayscale Copier Panasonic FP-7845 Black and White Copier Panasonic FP-D455S2 Grayscale Copier Panasonic Workio DP-3520 Copier Panasonic FP-7735 Black and White Copier
Can you Help with these Copiers problems?
Canon imageCLASS D761 Grayscale Copier
paper jamb
the paper is jambed at the exit... Answer This...
Copystar CS-2030 Copier
Copystar CS-3035
I have an original that is... Answer This...
Canon NP 6551 Black and White Copier
ELIMINATING SHUT OFF WHEN NOT...
Copiers
PANASONIC DP-1515P DRIVER
hello: i need the panasonic... Answer This...
Canon imageRUNNER C3220 Color Copier
Unable to set up scan feature.
I work at a UPS Store in rock... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
