I used to watch normal television on AV1 and dvd's on AV2 (Logik-LK-74PFDT Television). For some reason television is now on AV auto and I can't watch dvd's. Should I get back to factory settings and how do I do that? Please help!
  • 998 Answers
Try to enter the quick menu enter the set up mode go to AV connection
Posted on Oct 15, 2010
Hi my logik tv LK-74PFDT has a blue screen and a
Hi. Please find the user's manual. There must be a description about
this issue.
Oct 11, 2014 | Televison & Video
AV1 red, white and yellow cable ports not working. I use digital satellite service for my television through a box from my provider which only uses the AV1 port? I checked all the wires which were working...
Your post is a little confused (or I am!), why would a digital box only provide a low resolution output which is what the composite standard is - yellow video composite red/white=stereo audio.
You also say that you checked the wires, so you've seen the picture and heard the audio on AV2? So why not use AV2? There is no reason to use AV1 other than you may be using the other inputs for other equipment.
Check that the output from the cable box really is composite and not component, and if it really is composite check the AV colour system in the TV menu is set to Auto (or NTSC if you are in USA, PAL in Europe)
I think you (or I) may have misunderstood how to connect it, can you have a look at your cable box and see what the output sockets are labelled and report back/clarify also detail what your cable equipment is please?
thanks
May 17, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
I can't get the tv to program the cable connection to watch cable
use a scart lead to connect your cable tv box. then on your tv remote press the "source" button or press the "AV" button, you mainly have the options to choose AV1 and AV2 (AV2 is only available if your tv has 2 scart sockets) make sure the box is on and select any AV channel, you should now have cable tv.
Jul 17, 2012 | Disney Princess TV/DVD Combo
The television keeps tripping from av1 channel to tv/dtv channel
Unplug av1 and see if it stays on dtv. If it does then plug the composite cables into av2. If it switches back to av2, you have a bad main board.
Nov 16, 2011 | Televison & Video
Toshiba back projector 43' how do i make the av
Look at what input you plugged the DVD player into. maybe AV1 or AV2
Now on your remote, or on the front of the TV, push input until it stops on the one that your DVD player is plugged into.
Aug 27, 2010 | Toshiba 43HX70 43" Rear Projection...
Srt 2219b im try to setup to watch dvd and vcr. is there a trick.
If you are connecting your DVD and VCR to the TV using Scart leads, simply go into TV input option on your tv remote and switch to AV1 or AV2. i.e AV1 for VCR or AV2 for DVD player.
Mar 17, 2010 | Sylvania SRT2232S 32" TV
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
Panasonic dmr-ea38v vertical static
I would start by checking which scart leads are in which connections and check which av channel you have the player on.
e.g. AV1 connected to the TV, AV2 connected to the decoder.
Then the DVD player viewing/recording channel should be on AV2 not AV1. Does he have any high powered/frequency devices close by?
Jun 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
