Question about FUJIFILM FinePix J29 black Including Charger Lithium battery Digital Camera
ZOOM ERROR WONT GO OFF - FUJIFILM FinePix J29 black Including Charger Lithium battery Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 15, 2010
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Hi, the zoom wont retract and it says focus error
It won't focus because ya lens is out of focus due to it being stuck had same prob wig my Sony worked out cheaper to buy a new camera than have it fixed.very fiddley to repair hope if bin some help
Nov 23, 2009 | Fuji FinePix A500 Digital Camera
Fujifilm finepix a820 zoom error ... i turn the camera on and it wont focus... message on lcd screen is zoom error. it will not take picture and when i turn it off agan the zoom bit wont go back inside
    This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
   Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
    Thanks for using fixya.
Oct 28, 2009 | Fuji FinePix A820 Digital Camera
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom error
You have to make sure you take the lens cap off first before turning on the camera.Cheers Sandra
Mar 02, 2008 | Fuji FinePix S5500 Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Zoom error message
The higher end fuji's are good cameras. The A345 and A350 are a piece of crap. Low end Walmart cameras.
Oct 29, 2007 | Fuji FinePix A345 Digital Camera
Camera lens cover wont open
Get onto Sony Tech Support team. This is a camera failure the will honour the warranty here I am sure.
Jul 06, 2007 | Fuji FinePix 6800 Zoom Digital Camera
FUJIFILM FinePix J29  black Including Charger Lithium battery Digital Camera Logo
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
