Question about Sony STR-DG510 Receiver
NO Picure I purchased a STR-DG510 and after setting it up have found that I cannot get a video signal out of the using either component video cables inputs (RGB). I have to use composite RCA (yellow, red, white) to my TV (old TV). I know to use the HDMI you must use the HDMI out or you will not get a picture is this the same with RBG component?? My DVD is a SOny DVP-NS77H
  • 1prosource Jun 02, 2008
    Just recieved my answer from Sony. On the AV recieve whatever the input you use ie HDMI you must use the ssame output. So if I want to use Component (RGB) as inputs my output to my tv must be Component (RGB)
  • 1,512 Answers
Hi 1prosource
I concur:) Glad you got it sorted out. Any other dramas you may have, just give me a hoy :)
regards
robotek
Posted on Jun 03, 2008
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
Do the HDMI ports support audio or do I need to go buy optical cables to use them on my STR-DG510
The STR-DG510 carries video only over the HDMI port. Technically, this is a "pass-thru" port. Most older receivers are engineered to operate this way. Why? I don't know. You MUST provide the audio connection using a separate TOSLINK or RCA cable from the program source to the receiver while your video is connected via the HDMI port.
Stick to IT work, MSOFT IT pro. I got smart and bailed out being an IT guru. I got better things to do than screw around with the idiotic nonsense of Microsoft operating systems and applications being a thing of fashion rather than being useful and practical.
Aug 01, 2009 | Sony STR-DG510 Receiver
Sony STR-DG510 From component to HDMI
You have to use the same connection in and out. You can not mix inputs and outputs (Example- HDMI IN will not play on Component out and Vice Versa.)
Nov 18, 2008 | Sony STR-DG510 Receiver
Error 12 message on my Sony STR-DG510
error 12 is when you autocalibrate and do not have the microphone connected, when that is the case the receiver can not detect the speakers.
Nov 08, 2008 | Sony STR-DG510 Receiver
Inputs locked
The word UNLOCK may appear in the display if there is a problem receiving a digital audio signal. Follow the steps below to troubleshoot this issue.
  1. Ensure the correct input is selected to receive the Audio/Video (A/V) from the appropriate source.
  2. Ensure a digital cable is connected to appropriate DIGITAL jack.
  3. Ensure the other end of the digital cable is properly connected to the A/V source.
  4. Ensure the A/V source is set appropriately to output a digital signal.
  5. NOTE: The A/V source may have a DTS setting that needs to be turned on, or a DPCM setting that needs to be set toDolby Digital .
Jun 04, 2008 | Sony STR-DG510 Receiver
How do i un lock
May 27, 2008 | Sony STR-DG510 Receiver
No video output using either HDMI or component video
Make sure that these inputs are enabled. I'd have to confirm within the manual, but I believe that these have the HDMI section disabled by default.
Dan
Mar 21, 2008 | Sony STR-DG510 Receiver
Sony STR-DG510
I think you have to run a separate audio line from the dvd to the 510, because the HDMI is only passive
Mar 12, 2008 | Sony STR-DG510 Receiver
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
Sony STR-DG510 Receiver Logo
102 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
