Question about Yamaha P-5000 Amplifier
The garget blows the fuse and goes off - Yamaha P-5000 Amplifier
    Sergeant:
    Champion:
  • 387 Answers
If the fuse blowes when you swtich the power on its the power supply circuit. if the fuse blown after a short while that the Amp is on its possible that protection circuit is short
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Posted on Oct 15, 2010
What causes#37 fuse to keep blowing on 2004 chrysler pacifica
The fuse goes to the auto shutdown relay from there it goes to two powertrain control modules. Test the relay or replace or there is a short in the system
Oct 04, 2014 | 2004 Chrysler Pacifica
How to remove a garget from my ceelphone screen?
If its a touch based phone, then click on the gadget and drag it towards up,when you will see the remove option or something like that highlighted in red color(often),then leave the dragged ones inside that area.
For text based phones,install device manager software and then manually uninstall the unnecessary items.
Sep 18, 2013 | Sony Xperia go ST27i Smartphone - Unlocked...
#11 fuse on 01 lincoln ls goes to
Hi Aaron, I'm glad to help!
Aaron, anytime a fuse blows in any circuit its because that CIRCUIT has a dead short to ground somewhere in that circuit. You need to find out everything that fuse 11 goes too. Once you know all the components that circuit 11 goes to you'll need to unplug one component at a time until the fuse does not blow and replace that component (PART). NOTE: If after checking each part one at a time and the fuse still blows, then its time to check the wiring going to each individual component because it is shorting out somewhere against a metal object. Hope this helps and have an awesome day Aaron.
Mar 28, 2013 | 2001 Lincoln LS V8
I have a 2004 pontiac vibe, but the running lights are not working. When I replaced the fuse, it blew.
REPLACE THE DRL RELAY SEE IF FUSE STILL BLOWS.POWER FROM FUSE GOES TO RELAY BEFORE LIGHTS IF FUSE BLOWS STILL BAD DIMMER SWITCH COULD BE BLOWING FUSE.
Aug 31, 2010 | Pontiac Vibe Cars & Trucks
3amp fuse is blowing.
Disconnect the yellow wire from the thermostat and tape off the end. Turn the power back on. If the fuse blows, it is not in your wire nor the compressor contactor. If the fuse does not blow, turn off the power, reconnect the wire, and replace the fuse. Then, disconnect the wire from the compressor contactor and tape it off. Turn the power back on. If the fuse blows, it will eliminate the compressor contactor coil and will likely be a "short" in the wire itself. The yellow wire goes from your T-stat to your air handler and from your air handler, it goes to the oudoor unit's compressor contactor.
Apr 07, 2010 | Weather King 10PJA2501AH Air Conditioner
Blows fuse on left speaker
Check the left channel semicondutors for short circuits. Anything that blows a fuse is causing an overload. If one of them is acting like it was just a piece of wire, it will blow the fuse.
Jan 27, 2010 | Audio Players & Recorders
The previous owner installed an after market Alpine CD player, It is wired into the dome light circuit and has a dead short. The dome light fuse (#12) 15A blows intermediately after inserting a new one and...
This could be a component or a wiring fault. It is easier to check the components so:-
1)Remove lamp and insert new fuse.
If fuse goes again, disconnect stereo, replace lamp and fuse.
If fuse does not blow the dump stereo.
If fuse goes again, trace the wiring and
If it still blows, then the stereo is likely to be faulty
Dec 21, 2009 | 2000 Dodge Dakota Quad Cab
Blowing fuse 29
fuse # 29 in the dash fuse block is for the ECM. gasoline-15A, Diesel-10A
Dec 15, 2009 | 1999 Volkswagen Jetta
2001 MUSTANG GT BLOWS #11 FUSE UNDER HOOD FUSE PANEL
I don't know what #11 goes to,I have been in
electronics for over 22 years and every time
a fuse blows you have a short.
sometimes the fuse panel will tell you what
that one goes to.
Good Luck
Sep 09, 2009 | 2001 Ford Mustang
Yamaha P-5000 Amplifier Logo
76 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
