Question about Nintendo Wii Console
No arrow from remote - Nintendo Wii Console
  • 104 Answers
Check to be sure your Motion Sensor bar is plugged in and your aimed strait at it and a wireless one may not work so well
Posted on Oct 15, 2010
How to factory rest zenith plasma tv
Here give this a try and hope this helps.
  • Press the "Menu" button on your remote control. Use the up and down arrow buttons to highlight the video option. Press the arrow that points to the right to select the video option.
  • Use the up and down arrow to highlight the video reset option. Push the right arrow button on the remote control to select video reset.
  • Press the right arrow button on the remote control to return the video to original values.
Jul 06, 2014 | Zenith P60W26 60 in. HD-Ready Plasma...
RM-GA014 remote can't switch Sony Bravia 46" tv on
Follow this procedure to troubleshoot if the TV does not respond to the supplied remote control.
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the remote control buttons are jammed.
  4. Install fresh batteries into the remote control. IMPORTANT: Make sure the batteries are inserted in the (+ and -) direction shown inside the battery compartment.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV. IMPORTANT: Some locations can interfere with the IR signal from the remote control. Glass enclosures, as well as fluorescent or halogen lights, may prevent the IR signal from reaching the TV.
  6. Point the remote control at the IR sensor of the TV.
  7. Press the POWER button and other buttons to test TV operation. IMPORTANT: Do not hold down the POWER button too long. Doing so may prevent the remote control from operating the TV.
    NOTES:
    • If some of the remote control buttons operate the TV but others do not, the remote control may need replaced.
    • If all of the remote control buttons work, no further troubleshooting is required. Otherwise, continue troubleshooting below.
  8. Try using the remote control at varying distances from the TV. IMPORTANT: Using the remote control too close or too far away may prevent the IR signal from reaching the TV.
  9. Turn the Light Sensor setting to OFF.
    1. On the TV itself, press the HOME button on the TV.
    2. Using the up arrow or down arrow select Preferences.
    3. Press the INPUT button.
    4. Press the up arrow or down arrow to select ECO.
    5. Press the INPUT button.
    6. Use the up arrow or down arrow to select Light Sensor.
    7. Press the INPUT button.
    8. Press the up arrow or down arrow to select OFF.
    9. Press the INPUT button.
  10. Power reset the TV.
  11. Make sure the TV has the latest system software (firmware) update installed, if applicable.
The troubleshooting steps above should resolve the issue. If you completed all the steps and the issue is not resolved, service may be required or the remote control may need replaced. Contact the Customer Experience Center at (239) 768-7547 to speak with a service representative for further assistance.
Apr 07, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
I cannot open the remote.
Turn the unit over. You'll see two arrows marked "1" and "2". Put a fingernail into the gap between the two ridges of "1" and move in the direction indicated by the arrow. While keeping it there, put another fingernail into the slot of "2" and pull in the direction of the arrow.
The procedure almost requires three hands. but it can be done with two if you put the remote down on a tabletop.
Jan 20, 2013 | Nikon ML-L3 Remote Control
I am unable to set up my directv remote to shut off and on & volume up and down on TV
hi,
make sure slider on the top is all the way over to the left then..
hit menu down arrow to parental, favs, setup hit select down arrow to system setup hit select down arrow to remote down arrow to tv choose brand in right list find code
MOVE SLIDER ON TOP ALL THE WAY TO THE RIGHT POINT THE REMOTE AT YOURSELF HOLD DOWN SELECT AND MUTE UNTILL LIGHT BLINKS TWICE
ENTER CODE
LIGHT WILL BLINK TWICE AGAIN
TRY THE BUTTONS
IF IT DOESENT WORK TRY A DIFFERENT CODE
OR GOOGLE DIRECTV CODES
NAVIGATING THE DIRECTV WEBSITE FOR CODES IS NEARLY IMPOSSIBLE. GOOGLE CODES.
JM
Jan 24, 2010 | Televison & Video
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
My remote won't start the fire in my vent free fire place.
Mine did the same thing. What happens is when the batteries die and the remote sits, the remote loses its address. I found this link to the remote manual online. You have to locate your receiver in the fireplace insert. On the receiver there is some dip switch settings. Open up the link below and go to the appendix at the bottom and find your address of the receiver, mine was 005. Go to your remote and power on. Hit the up arrow until you are at the timer. Now hit the left arrow on your remote 10 times, this will diplay the address of the remote, mine was 000, change this number to match your address of the receiver by hitting the up arrow on the remote, I changed mine to 005. Now hit the left arrow again and this will take you out of programming. Power on your remote and should work, enjoy.
http://www.montigo.com/manuals/SIT_remote_controls.pdf
Nov 25, 2008 | Heating & Cooling
No picture
Try changing the settings back to factory default. Both of my surround speakers stopped working, and doing this brought them back. If your remote functions properly, it can be done by hitting this exact sequence when in the DVD mode:
Setup>Right Arrow>Right Arrow>Right Arrow>Right Arrow>Enter>Down Arrow>Down Arrow>Enter
Note: The Arrow buttons are the ones that surround the Enter button.
This is a very poorly designed system, and the remote will not work from slight angles. You must be directly in front of the unit for the best signal reception from the remote.
Aug 23, 2008 | Curtis DVD6041 System
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Nintendo Wii Console Logo
103 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
