Question about Sony PlayStation Portable (PSP) Console
The bottom buttons on my psp don't work at all (like my volume, home, select, and start button)
  • Anonymous Mar 26, 2009
    i have the agzact same problem!
    Problem Solver:
  • 11 Answers
U probably fryed a curcit its most likely it cant be fixed buy or get it replaced
Posted on Jun 02, 2008
Buttons not working on my psp 3000?
Thank yo for contacting fixya, experts would be with you in a moment,
ascertain devices user guide and instructions on maneuver processes are functionality occurs. Normally proceses would comprise how to operate entire every requisite proceedings of expection on acquisition.
May 13, 2013 | Sony PlayStation Portable (PSP) Console
Tip
How to fix Volume issues in PSP Portable
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
on Feb 13, 2010 | Video Game Consoles & Games
Some of the buttons (Start, Select and sometimes Home), don't work. What's the problem?? And sometimes, in game, home keeps showing!
the buttons are stuck take it apart and clean them and if that does not work buy replacement buttons from ebay or amazon
Jan 30, 2012 | Sony PlayStation Portable (PSP) Console
After pressing the audio button on my psp the screen would go black and white from bottom to top then would go back to normal what i tried is to take out the memory card and tr to press the audio...
Hi, I've had the same problems for about a month now. I have a psp fat (psp-1000) with cfw. 5.50. I was playing ZHP unlosing ranger when the same thing happened.
I use the lowest brightness setting to lengthen game play time. I keep using the audio button (The one you hold and turns the sounds mute or back.. right?) for the game then when i reset my game (press home and start the gameover..) the brightness suddenly keeps on changing even making the whole screen black. After 5 minutes? it stops but then when i press the down or square, triangle button the brightness changes sometimes thats the only thing the button does.. i found a temporary fix for this, i put it sleep mode then turn it on again and it stops.. the buttons go back to normal, for a while.
It goes on and on even with other games. It just stops after 10 minutes later or more than starts happening again everytime the brightness or audio button is pressed.
We scanned it for viruses on a computer and it just kept on blinking everytime it responded to the scan. No virus were found but after that when we disconnected it from the computer the brightness problem stopped for a good long time.. we avoided pressing the brightness and audio buttons. but recently its happening again.
and now just got worse. I was playing Socom Fireteam, and when you accidentaly go to the start menu, you have to press "select" to exit and continue the game. But the "select" button wont work!
so i quit the game and startover.. when this happened for the 3rd time. When i pressed "home" button and was asked if i really wanted to exit the game i couldnt move to "yes" and couldnt press the "O" or "X" buttons.
So i turned off my psp and when it went back on, I couldnt press anything anymore. except, the volume buttons and select (the vsh menu appears)
I searched for help from the internet, found "disable your vsh menu" remedy.
It worked! but when i played the game, the "cwcheat" menu keeps on appearing (seplugin that appears when you press select button). It wouldnt stop >.<
So we disabled that too.
Now playing God of War Ghost of Sparta, and one part, the start menu kept on appearing! we'd close it so that we could push one of the levers in the game but then it pauses the game again.. it stopped after a while. then it happened again only slight.
Found a comment on a "select button problem" and it said that it was the:
"parts that were Ribbon style, with it was the start and select button and the volume/sound" he had that parts?
found same problems around the net, some posts from 2009.
found decent posts and solutions here:
http://forums.qj.net/psp-general-help/151111-psp-slim-start-button-stuck.html
the best one says buy a new "flex bar" or "home bar". It goes by many names, but it's the metal bar that has all of the bottom row buttons on it (home -> start) It's usually under $10 USD and obviously the right thing to do.
got another comment that says it worked from him when he bought one himself.
Glad I found others, and that I could share this.. wish it makes things better.
Hope it works out for all of us!
Another thing, Merry Christmas!
Dec 02, 2010 | Video Game Consoles & Games
My volume dont work is there anyway i can troubleshoot it or restart the whole thing?
Feb 13, 2010 | Sony PlayStation Portable (PSP) Console
My psp volume button will not work can you help but its only the one to turn it up not down
When this happens, it's because the volume button on the inside is messed up. Usually it's because it's dirty or sticky and sticks down [or presses itself]. You can try opening it and cleaning under the volume button. If that doesn't work, you may need to replace the home/volume/start/select circuit ribbon cable. If you're not comfortable opening it, check the following company -- they would repair something like this for $29
http://store.richspsxparts.com/clforpsprese.html
Nov 16, 2009 | Sony PlayStation Portable (PSP) Slim...
My psp keep going to home by itself.
When this happens, it's because the home button on the inside is jammed. Usually it's because it's dirty or sticky and sticks down [or presses itself]. You can try opening it and cleaning under the home button. If that doesn't work, you may need to replace the home/volume/start/select circuit ribbon cable. If you're not comfortable opening it, check the following company -- they would repair something like this for $29
Oct 24, 2009 | Sony PlayStation Portable (PSP) Console
Select Button Seems To Be Jammed Through Software
downgrade your psp if u can do it yourself ...... if not then try upgrading it again
Aug 28, 2009 | Video Game Consoles & Games
My psp home,select,start,mute,and screen button does not work!
It is more than likely the cable that is behind the buttons. We are going to be adding this repair service to our website today. I recommend getting a full diagnostic however to find out any and all problems with your PSP.
You can visit and pay by a SSL encrypted checkout through Paypal. You don't even need to have a PSP required. If you have any questions you can call or email us. All of our contact information is on our website - psp repair.
Feb 22, 2009 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
122 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
