Question about Dell OptiPlex GX280 PC Desktop
How do i open my dell computer to install new memory module
  • Dell Master
  • 7,733 Answers
Most PC had 3-4 screws on the back.Unscrew tehm and slide the side of the case back until if completely out. There you will find the Mmodules.
Posted on Oct 15, 2010
Computer beep codes
Installing Memory), and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • Installing Memory).
  • Memory Installation Guidelines).
  • Replacing the Battery).
  • If the problem persists, contact Dell.
  • 6
    Video BIOS Test Failure
    Contact Dell.
    7
    CPU cache test failure
    Contact Dell.
    Nov 11, 2013 | Dell Computers & Internet
    What does two beeps on a dell Inspiron 530S mean and how do you get it out of power saving mode?
    Power off. Wait a full minute. Discharge static from your hands by touching exposed metal part of chassis (case). Open your case and re seat memory chips.
    Jul 07, 2012 | Dell Inspiron 530 Desktop Computer
    My dell optiplex gx620 does not start and it shows no. 3 and 4 lights illuminated on its front . what could be the problem.?
    One of your memory chips is bad.
    Maybe your memory is bad or the memory slot is bad.
    Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
    Diagnostic Lights caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. To help you troubleshoot a problem, your computer has four lights labeled "1," "2," "3," and "4"on the front or back panel. The lights can be off or green. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. If the POST portion of system boot completes successfully, all four lights display solid green. If the computer malfunctions during the POST process, the pattern displayed on the LEDs may help identify where in the process the computer halted.
    note.gif NOTE: The orientation of the diagnostic lights may vary depending on the system type. The diagnostic lights can appear either vertical or horizontal.
    Light Pattern
    Problem Description
    Suggested Resolution
    The computer is in a normal "off" condition, or a possible pre-BIOS failure has occurred.
    The diagnostic lights are not lit after the computer successfully boots to the operating system.
    Plug the computer into a working electrical outlet and press the power button.
    A possible BIOS failure has occurred; the computer is in the recovery mode.
    Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
    A possible processor failure has occurred.
    Reinstall the processor and restart the computer.
    Memory modules are detected, but a memory failure has occurred.
    • If you have one memory module installed, reinstall it and restart the computer. (see "Memory" for instructions on how to remove and install memory modules.)
    • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
    • If available, install properly working memory of the same type into your computer.
    A possible graphics card failure has occurred.
    • If the computer has a graphics card, remove the card, reinstall it, and then restart the computer.
    • If the problem still exists, install a graphics card that you know works and restart the computer.
    • If the problem persists or the computer has integrated graphics, contact Dell.
    A possible floppy or hard drive failure has occurred.
    Reseat all power and data cables and restart the computer.
    A possible USB failure has occurred.
    Reinstall all USB devices, check cable connections, and then restart the computer.
    No memory modules are detected.
    Memory modules are detected, but a memory configuration or compatibility error exists.
    An other failure has occurred.
    This pattern also displays during System Setup and may not indicate a problem.
    • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
    • Check the computer message that appears on your monitor screen.
    After POST is complete, all four diagnostic lights turn green briefly before turning off to indicate normal operating condition.
    None.
    Jun 06, 2012 | Dell OptiPlex GX620 PC Desktop
    My system is recognizing only half of the new module's memory
    Do you have the right memory for your Dell?
    Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
    Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
    Nov 20, 2010 | Dell Dimension 1100 PC Desktop
    Numbers 3 and 4 are flashing green on the front of the computer
    Dell website says that it means that the PC has memory installed, but there is a problem with it. It's possible that you have more than one memory module and one has gone bad. If you know how, you could try removing one, restarting the PC to see if the error is eliminated. If not, put the removed one back in and remove a different one until the error goes away. You may have to buy a new memory module. Additional troubleshoot tips on the Dell website at this link: http://support.dell.com/support/edocs/systems/dimE521/en/SM_EN/adtshoot.htm#wp1056411
    Oct 21, 2010 | Dell Dimension E521 PC Desktop
    Hallo to Experts plz any one will help me.dearz my system is gx270 dell.its back lights A&B remain orange while i start p.c plz any one tell me about it plzzzz...
    This generally signify , that the memory modules are detected in the system, but there is a memory failure.
    You can try the following steps
    In case you need a user manual to know how to open the computer tower you go the following link
    User manual
    Thanks for using Fixya
    Proton
    Oct 13, 2010 | Dell OptiPlex GX270 PC Desktop
    Pc doesn't start properly, and displays a 1 & 3 on the front panel
    May 11, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
    My Dell Optiplex GX520 will not boot. There is no video output and the 3 and 4 diagnostic lights remain on.
    If 1 & 2 are off ... then you have problems.
    • If you have one memory module installed, reinstall it and restart the computer. (see Memory for instructions on how to remove and install memory modules.)
    • If the problem persists, contact Dell (see Contacting Dell).
    According to Dell's notes:
    Their remedies are:
    Jun 17, 2009 | Dell OptiPlex GX520 PC Desktop
    I would like to install bigger memorie in my latitude c610, how do i access the slots ?
    http://support.dell.com/support/edocs/systems/latd600/sm/upgrades.htm#999869
    Memory Module, Mini PCI Card, and Modules Dell™ Latitude™ D600 Service Manual
    bullet.gif Memory Module
    bullet.gif Mini PCI Card
    bullet.gif Modules
    Memory Module caution.gif CAUTION: Before working inside your Dell™ computer, read the safety instructions in your System Information Guide. caution.gif CAUTION: Toprevent static damage to components inside your computer, dischargestatic electricity from your body before you touch any of yourcomputer's electronic components. You can do so by touching anunpainted metal surface. note.gif NOTE: Memory modules purchased from Dell are covered under your computer warranty.
    1. Follow the instructions in "Preparing to Work Inside the Computer."
    2. Turn the computer over, loosen the captive screw from the memory module cover, and lift the cover.
    upgrade7.jpg notice.gif NOTICE: To prevent damage to the memory module connector, do not use tools to spread the inner metal tabs that secure the memory module.
    1. If you are replacing a memory module, remove the existing module.
    notice.gif NOTICE: Handle memory modules by their edges, and do not touch the components on a module.
      1. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      1. Remove the module from the connector.
    upgrad10.jpg notice.gif NOTICE: If you need to install memory modules in two connectors, install a memory module in the connector labeled "JDIM (Slot 1)" before you install a module in the connector labeled "JDIM2."
    1. Ground yourself and install the new memory module:
      1. Align the notch in the module with the slot in the center of the connector.
      1. Slide the edge of the module firmly into the connector, and rotate the module down until you feel a click. If you do not feel the click, remove the module and reinstall it.
    note.gif NOTE: If the memory module is not installed properly, the computer does not boot. No error message indicates this failure.
    1. Replace the cover and screw.
    notice.gif NOTICE: If the memory module cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    1. Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
    2. Turn on the computer.
    As the computer boots, it detects the additional memory and automatically updates the system configuration information.
    Dec 30, 2008 | Dell Latitude C610 Notebook
    Dell optiplex Gx 150
    This is a problem with your memory.
    During POST, the computer checks the computer's memory, determines the amount of installed memory, and then writes to and reads from the number of available bytes to ensure proper operation.
    Basic Checks:
    • If an insufficient memory message appears, save and close any open files and exit any open application programs not in use.
    • Consider installing additional system memory.
    • Run the System Memory test in the Dell Diagnostics.
    • Reseat the memory modules.
    • Restart the computer.
    If the problem still exists after you complete the basic checks, fill out the Diagnostic Checklist as you perform the following steps.
    caution.gif CAUTION: Before you perform this procedure, see "Safety Information."
    1. Reboot the computer.
    Does the RAM count displayed correctly match the actual amount of memory installed in the computer?
    Yes. The computer needed to update the memory count. The problem is resolved.
    No. Go to step 2.
    1. Run the System Memory test group in the Dell Diagnostics.
    Did any of the diagnostics tests fail?
    Yes. Contact Dell for technical assistance.
    No. Go to step 3.
    1. Turn off the computer and peripherals, disconnect them from their electrical outlets, wait at least 5 seconds, and then open the computer cover.
    2. Rotate the power supply away from the system board.
    3. Replace the memory module(s).
    4. Close the computer cover, reconnect the computer and peripherals to their electrical outlets, and turn them on.
    Yes. The memory module(s) were defective. The problem is resolved.
    No. Contact Dell for technical assistance.
    Nov 06, 2007 | Dell OptiPlex GX260 PC Desktop
    Dell OptiPlex GX280 PC Desktop Logo
    mukhtar21 shaikh
    mukhtar21 shaikh
