Question about Avaya 9640G
9640 keeps looping and hangs at "Waiting for LLDP" gets "Bad FileSv Address" every 3rd cycle?
Configuring the switch S5700-28P-LI-AC, I had no idea: how to Check Whether the IP Address in the NeighborInformation Is Correct?
Run the lldp management-address command to configure the switch management address of the local device. Then view the management address of the local device on the neighbor device to check whether the displayed IP address is the same as the configured one.
The more information about technical support you can consult with our technician - Bill, and his e-mail address is as below:
bill@huanetwork.com
S5700 28P LI AC Price Buy Huawei S5700 28P LI switch Huanetwork com
May 20, 2014 | Computers & Internet
Hello, and thanks for any help you can provide. My Canon ImageRunner C5180 sometimes hangs on "Waiting to Print ..." That is, someone sends a print job, "Waiting to print..." begins to...
i think that the problem with hanging hides in your PC network and incompatibility of some files with printer driver version or something like this. Try to find from which PC do you have problems and look for software reasons. This machine is to big to make little problems...
Can you COPY when the machine trys to print? If you can, I think that everything with CANON is OK.
If you type the IP address of Canon in some of your internet browsers you will get instant access to WEB MONITOR and there must be error log somewhere.
Good luck
pifonski
Mar 02, 2011 | Canon imageRUNNER C5180 Color Copier
Keep hanging up in wash cycle
Please report all error codes and try to time where in the cycle it is happening. The reasons it might hang are waiting for water due to blockage, unable to drain due to pump or outlet pipes blocked, unable to heat as heater/ thermostat faulty, door showing as open (even though it isn't), motor not turning when it should etc etc. You haven't given enough info or model number, to diagnose.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | LG Washing Machines
Since Saturday evening I have been unable to connect to BBC iPlayer using Expat Shield. It seems to be caught in a loop - waiting for server - starting VPN process - waiting for server - etc. and just...
If you're using Expat Shield that means you're not living in UK. BBC iPlayer work only when it recognizes an IP from UK so you have to set your software to an UK IP address, or use other IP hiding software.
Jan 31, 2011 | Computers & Internet
System locked screen says Waiting for about 30 seconds then turns blank for about 30 seconds then goes back to waiting screen. is in a loop
prees Esc button the i hope u will able to break this cycle otherwise check ur start up by opening it in safe mode
Nov 24, 2009 | Computers & Internet
Bottom thread is very very loose during stitching, looped up
Looping on bottom:
Great description, that helps a lot. Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Kent581
Mar 03, 2009 | Husqvarna Viking 1
Cannot log onto network - get message "waiting for network services"
On the DNS-server (Active Directory) you have to generate spesific IP-address for each thin clients MAC-address.
Jun 02, 2008 | WYSE Winterm S30 Network Terminal
KDC-9640 wont play
SINCE YOUR JENSEN ISNT WORKING HOW ABOUT YOU SEND ME THE POWER PLUG OR MAYBE SOME ADVICE WHERE I CAN GET ONE????????
Apr 28, 2008 | Jensen KDC-9640
Open Questions:
Avaya 9640G Logo
1,755 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
