Question about Vulcan AUW230A Heater
I have moved into a old home with Vulcan Wall heater (model no: 4690001), no manual, having problems starting pilot light to get heater going.
    Genius:
  • 1,417 Answers
Here are the solution below to solve the problem on your on the mater of do it your self one after the other (step by step).
The first sign of trouble with your water heater's pilot light is usually a cold shower. Your heater's pilot light allows the burner to cycle on and off while maintaining the water in the tank at a constant temperature. When the pilot light goes out for any reason, the thermocouple closes the burner's gas supply valve to prevent gas escaping and filling your house.
When your pilot will not light or does not remain lit, you might be able to save the price of a service call by taking a few minutes to troubleshoot the problem.
Difficulty: Moderately Easy
INSTRUCTION
  1. 1 Remove the pilot light access cover. It is located near the bottom of the tank. If you smell gas, do not attempt to light the heater. If the smell does not dissipate, replace the heater's control valve before proceeding. The control valve is the box located by the access cover. It consists of the on/off/pilot dial as well as the thermostat dial. Consult manufacturer's documentation for replacement instructions on your model.
  2. 2 Turn the thermostat on the water heater to the lowest setting.
  3. 3 Turn the gas control valve to the "Pilot" position.
  4. 4 Inspect the burner area with a flashlight. Clean out any dust or debris before attempting to light the pilot.
  5. 5 Press the gas control valve down in the "Pilot" position, and hold the flame from your match or lighter underneath the pilot light.
  6. 6 If the pilot fails to ignite, check the gas supply to the heater. Make sure all supply valves are open.
  7. 7 If the gas supply is good, the pilot light's orifice or gas jet might be plugged. The orifice is the small tip attached to the pilot light's gas supply tube. Use a small wrench to remove it. Inspect the tip and remove any obstruction by tapping gently against a hard surface or blowing through it. Once you are satisfied that the orifice is clear, try lighting the pilot again and proceed to the next step. If it still does not light, replace the gas control valve.
  8. 8 Remove the flame from the pilot light as soon as it ignites. Continue to hold the gas control valve down for at least two minutes to allow the thermocouple to heat up. The thermocouple is the small metal rod located directly above the pilot light. It is designed to allow the burner to operate only when the pilot light is functioning.
  9. 9 Release the gas control valve. If the pilot light goes out, check the fittings between the thermocouple and the gas control valve. A loose fitting to the control valve can keep the thermocouple from operating properly. If the fittings are tight and the problem persists, replace the thermocouple.
Thank you and thanks foe using fixya.
Posted on Oct 15, 2010
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Nov 11, 2010 | Williams 6508732 Gas Heater
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
The pilot light has gone out on an old Vulcan gas wall heater. How do I turn it back on?
You probably need to replace the thermocouple before you will be able to get it lit.
Oct 14, 2009 | Vulcan Heating & Cooling
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Vulcan AUW230A Heater Logo
567 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
