LG Washing Machine WD-10165F: After completing a wash cycle, it simply starts again and again without ever stopping, washing the same load over and over? What can I do to reset machine or something? Will I require new parts?
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Posted on Apr 23, 2008
  • 489 Answers
SOURCE: LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Posted on Apr 27, 2008
  • 11 Answers
SOURCE: smelly washing machine
Run a wash cycle with only some bleach in it. That works for us everytime ours gets a bit stinky... Good luck!
Posted on May 19, 2008
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
  • 98 Answers
SOURCE: Washer won't drain.
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Apr 01, 2009
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
    Hi!
    The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
    If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
    Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
    I HAVE WD-10165F LG WASHING MACHINE, BUT ITS DRUM IS NOT WORKING
    Possibly the Main Capacitor is leaked/ burned.Try replacing it with new ones.
    To locate it, you can follow the schematics diagram behind the machine.
    It's look's like a mini can with cable, sometimes the color is white, and on the body written 25uF/400 VAC, or something like that.
    Hope this work, if still won't, contact me for furthure assistant.
    Oct 23, 2009 | Washing Machines
    Washer stops several times in the middle of cycle
    possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
    Oct 03, 2009 | GE Profile Prodigy WPSE4200A
    LG WD-3243RHD Front Load Makes grinding, crackling noise
    Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
    Feb 10, 2009 | LG WM2432H Front Load Washing Machine
    Washing machine keeps stopping mid cycle
    If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
    Nov 20, 2008 | LG WD-1280FHD Front Load Washer
    WD 8030 W Front Loader
    the load is off balace you may need to add more clothes or stop the machine and wring the water out and try to spin again( i also have an LG and mine wont spin if ther is only one item in it
    Feb 13, 2008 | LG WM1812C Front Load Washer
    LG Washing Machine All-in-One
    Some magic happened today!
    I got the thing (wd-12331ad) to dry without having to run a wash first!
    Also, I seemed to get it to do a spin only run...
    The way to get it to dry :
    (for a set time - I've not managed to get any of the auto-dry settings to work)
    from machine being off:
    > press the power button.
    > press the "Dry" button 'til "Time" lights up
    >>> press "Dry" again to get the desired duration
    > press the spin button 'til the spin speed shows blank/ the RPM light goes out.
    > press "Start/Pause"
    It will then dry for the number of minutes specified!
    Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
    Something to note:
    - The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
    For "spin only" from machine being off:
    >>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
    >>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
    >>> pressing spin repeatedly, cycles through the spin speeds.
    Things I don't know:
    - I don't know if you can combine spin and heat.
    - I don't know whether the auto-dry programs are available
    - I don't know what other programs are available from the "Dry"/"Spin" buttons
    ...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
    Hope that helps.
    Will
    Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
    Washing Machines Logo
    43 people viewed this question
    Top Washing Machines Experts
