My washing machine wont spin and is displaying E20
  • 12,061 Answers
It would appear that your machine is not emptying the water out. Could be a kink in the hose or pump stuck/failed.
Posted on Oct 15, 2010
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
My Zanussi ZWF1658W washing mashine will not spin and drain the water it has a E20 error message on the display
I believe E20 is a blocked filter.
There should be a small door on the front of the machine almost at floor level.
BECAUSE THE MACHINE IS, I PRESUME FULL..... do this:
Unplug from mains
Tip machine backwards at about 45% so the water is not going to come gushing out of the filter when you remove it
Open the little door
remove and clean the filter
replace it
close door
put machine flat on floor agin
plug back in
start a cycle
Pray
Feb 26, 2011 | Washing Machines
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Mar 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
My washer wont spin out it has a code that is E20
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 12, 2008 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
