Question about Casio Watches
How can I stop my casio 2963 from beeping when I change modes?
G-shock casio 5034 won't beep when i need to change daylight saving
Module No 5034 won't beep except for alarm use.
Jan 23, 2013 | Casio Watches
How to set the time on my Casio g shock 5121
You should be in time keeping mode to do this. The manual say's press the "A" button for 5 seconds not 3 seconds. "A" button should be pressed until you hear 2 beeps (5 sec), if you only hear 1 beep (3 sec) don't let go of the "A" button, if you do you certainly will not be able to change the time, zone, dst, date, etc...
Mar 30, 2012 | Casio Watches
On my Casio G-shock GW500A, the time is off. i dont want it on 24time and its an hour ahead
Sounds like you're set for the wrong time zone, and your 12h/24h setting is off.
To change time zone: Hold down the adjust button until it beeps. Your time zone will be flashing at the bottom of the display. Use the Time Memo and/or Receive buttons to change it to the correct time zone. Then... To change to 12H mode: Press adjust again. 12H or 24H will be flashing at the bottom. Use the receive button to cycle the mode. When it's what you want, press adjust once more.
Feb 26, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Hi, My Casio Edifice EQS-500C watch doesn't beep when I press "mode" button anymore. I did something wrong I guess when I was setting the time.
Hi as far as I know this watch model only beeps when you are configuring time and when you want to go back to time mode from any other one (chrono, world time or alarm mode) by pressing left lower buttom for a few seconds. It only beeps if you have set the alarm. It does not have light either. Hope this clarify.
Rafael
Dec 08, 2010 | Casio Watches
My G-Shock doesn't beep every hour, how do i get it to do that?
To make it beep every hour you must first put it on the alarm mode. Then, press the START-STOP button until a little bell shows up at the left. Hope it helps!
Oct 01, 2010 | Casio G-Shock G2600 watch
How do i set my casio databank to beep every hour
Hello I was in the same problem the last 5 hours causea icant find my owner manual, i put a new battery on my "oldie" but great watch and pusshin and seting i got it....
You have to put in "alarm mode", remember you have to push BOTON MODE. Then you will be at "stand by mode", "data bank(phone) mode", "world time mode", "alarm mode" "chrono mode", and set (analog watch) mode"
then you are in "alarm mode" then push "REV and FWD BOTONS" at the same time, one time, or two times or three times, until the "beep icon and bell icon" are in ON mode
Good look
sareg@hot....
Sep 25, 2010 | Casio Watches
Nike watch
In TIME mode - not ALARM - top right hand button marked "START/LAP" toggles hourly beep on/off. As not in ALARM menu, easy to put on unintentionally.
Nov 07, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Casio Illuminator w-94h
Hold down the "Adjust" button (top left) for three seconds. It won't adjust unless you hold the button down.
Press "Mode" (bottom left) to change what you're adjusting, seconds, hour, minute.
Press the top right and bottom right buttons to adjust the number up and down.
Press "Adjust" again when you're done setting the watch.
To change date, alarm, alternate time, etc, press "Mode" to get to those functions before hitting "Adjust."
I hope that helps.
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Watches Logo
103 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
