Question about Microwave Ovens
Burnt bulb in GE JE1590sc001 convection microwave
My interior light bulb in my GE JE1590sc001 convection microwave is burnt out and I cant locate it to replace it. Please help with diagram or instructions. Thank you!
  • Anonymous Mar 31, 2014
    can't locate
  • Microwave Ovens Master
  • 5,568 Answers
You can locate it by looking inside the cavity for an area that is perforated.
If this area is not a panel that can be removed, replacing it may (often) require removing a few sheet metal screws along the rear edge of the unit; rarely is the housing held on with more than that.
With the screws removed, lift up on the rear edge and pull toward the back.
DO NOT LEAVE IT PLUGGED IN!
Also, because there are components that may keep a charge (capacitors) for hours, I would recommend letting it sit unplugged overnight before removing the housing.
The bulb may be either a cylindrical type such as many sewing machines use or a smaller version of a standard bulb.
Neither of which anyone ever has at home, of course.
Any of the large 'home improvement' stores should have these 'made in China' bulbs at an inflated price.
Posted on Jun 03, 2008
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
GE microwave JES 2251 SJ02 Light bulb that illuminates oven interior burnt out. Have correct replacement bulb (I think!). Can I remove oven cover and replace light bulb while keeping a good distance away...
sTEVE, THE CAPACITORS HOLD A CHARGE EVEN AFTER THE SYSTEM IS UNPLUGGED. A good rule of thumb would be to allow at least 48 hours for the capacitors to discharge before even getting nea them. Then, yes, you can replace the bulb. Thanks
Jan 27, 2011 | GE Microwave Ovens
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
Cant get out the burnt out bulbs
dismantle the unit to reach the burnt out bulbs
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 14, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The interior light on my microwave convection oven doesn't light.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 20, 2008 | GE JVM1490 Convection/Microwave Oven
Delonghi AC930AMQ Microwave, Interior Light Bulb
The bulb is usually run by one of the door switches, but in some cases they are run by a relay on the board.
I would suggest you look over our files on safety & door switches here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/doorsw.txt
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | DeLonghi MW 605 Convection/Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Microwave Ovens Logo
654 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
