Question about Bush Televison & Video
Picture is too wide - Bush Televison & Video
    Top Expert:
  • Bush Master
  • 74,383 Answers
It may be due to power supply regulator inside the tv circuit. Your TV is working at overvoltage. most of todays TVs are working at 110v DC. It is derived from a switched mode power supply section inside the tv circut board itself. You must rectify it soon, otherwise it may lead to several problems later, including filament burn of picture tube. Contact an expert mechanic soon.
Posted on Oct 15, 2010
Installed comcast cable box to emerson flat screen tv. it is hdmi, 1080. now i don't have a full screen picture.
Try using the wide mode. There are multiple screens you can get such as wide, zoom, full, and wide zoom. Go through these til you get the picture you want.
Mar 26, 2015 | Emerson Televison & Video
Picture too wide on tv
Sounds like you have the "Wide" mode set to Zoom or wide zoom. Also if you are on Comcast cable the cable box has a setting of Zoom and full. Set your TV's zoom setting to "Full" and the cable box to Full. I don't have an LG so you'll have to find these settings yourself..
Feb 25, 2015 | LG 47LM6700 47" Class FuHD 1080p LED LCD...
How do i fix a too wide picture on my sony kdl40ex500?
Why are you using 4:3 letterbox? It might be the default aspect ratio but widescreen tvs should be set to 16:9 aspect ratio.
Aug 22, 2014 | Sony KDL40EX500 40 in. HD-Ready TV
How do I get the picture to be as big as the tv
The picture is controled by the zoom on the tv remote and on the reciever remote. if you're looking at Wide screen containt the your screen will be black on the top and bottom, zooming will make it fit but you will loose some left and right info. Only HD containt formated for home tv's will, like Oasis, or National geographics, ect will give you full screen. Wide screen is for Movie theaters not TV. This realy sucks but to get a large Wide Screen Picture, You have to buy a supper large tv otherwise, the Wide screen image is small and wide and preaty much anoying with a short wide picture with black bands on top and below..
Sorry. We all have to live with this stuff.
Jun 18, 2012 | Emerson lc220em1
Small picture from player (not wide screen)
Set the all settings to wide, not auto as if the player is set to 4:3 format then this sends a signal to the tv telling it so.Go into the setup menu and choose picture format set to 16:9 or wide. Set the tv to auto and this will keep all picture inputs to origional format. I.E. if it was recorded in 16:9 it will play in 16:9. You could set the tv to 16:9 but it will distort the picture on 4:3 recordings.
May 31, 2009 | Sanyo DRW-1000 DVD Recorder/VCR
Akai TV picture is too wide
HI..
You need to change the video format in the setup routine
Theres'
4x3, Letterbox or wide etc.
Change that until your picture looks better
Jan 12, 2009 | Akai LCT3201AD 32 in. LCD Television
Can't get picture in wide format on the menu. 16:9 and 4:3 only.
I had the same problem with a 50". The only way I could fix it was to set my Bose system to 4:3 format and the tv to 16:9. Now you can use the zoom to get the right size
good luck
eltjo
Nov 21, 2008 | Samsung LN-T4053H 40 in. LCD Television
Picture to wide
This trouble symptom picture wide or"blooming", the picture becomes dim even with the brightness control full on,and there is an abnormal enlargement of picture or raster.Usually,the enlargement is uniform,but there may be some defocusing.In some circuits,the brightness control operatesin reverse(rotating the control for an increase in brightness produces a decrease) after reaching a critical point on the control. If the picture wide is not accompanied by insufficient width(a symptom of horizontal output failure) the probable cause is a high volatge circuit ony,particularly the HV rectifier and HV winding.Any circuit problem that reduces but does not completely eliminate the high-voltage output to the picture tube second anode can cause overscan. The most likely defects are leaking high-voltage capacitors,defective high voltge tube rectifiers,leaking high voltage leads,defects in high voltage circuit protective resistance,and shorted turns in high voltage winding of the flyback transformer.
Hope this may help you;
DON'T FORGET TO RATE:
Regards,
Sep 06, 2008 | Toshiba 32AF45 32" TV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Vizio 37'' TV
This is normal.
Oct 21, 2007 | Vizio L37 Television
Televison & Video Logo
32 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
