Question about Garmin zumo 550 GPS Receiver
Zumo 550 i can't hear direction or phone through my headset above 30mph, even with the volume set at 100%. Voice direction isn't much better in car above 30mph either. Mp3 is very good both in car and on bike. If you have a solution please keep it simple as im not good on electronics
  • 174 Answers
There is an extra audio menu under the wrench symbol, this one differs from the front panel set both of these to 100%, should be better!
Posted on Jun 10, 2008
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Jul 18, 2011 | Plantronics CS70 Wireless Headset
I am using a Koss CS-100 Headset, and i only have one 3.5mm plug on my laptop so im using a splitter on it, and my laptop wont detect it, and even when i just plug one into the 3.5mm plug it still wont...
Windows isn't directing sound to the headset plug. This can be changed under control panel sound.
Sometimes it will asign itself if you turn on the computer with the headset already plugged in.
Also check the settings under all programs --- accessories -- entertainment -- volume control
and make sure the volume isnt too low or muted for the device.
May 16, 2011 | Koss CS-100 Headset
Can the audible volume be turned up louder on a
I think the only solution for you my friend will be too invest in a headset of some kind which should plug into your unit which will help you to hear better.
May 03, 2010 | Garmin nuvi 650 GPS Receiver
No voice is heard even though it is connected
If you cannot hear the voice eventhough it is connected, do as follows:
• Ensure that the headset is charged, switched on, and paired with and
connected to your phone.
• Ensure that the Bluetooth feature is activated on your phone.
• Check that the headset is within 10 meters (30 feet) of your phone and
that there are no obstructions between the headset and the phone,
such as walls or other electronic devices.
• To reset the headset if it stops functioning, although it is charged, plug
the headset into a charger, and briefly press the power key and the
middle of the volume key. This reset does not clear your settings (for
example, pairing settings).
please dont forget to rate me.....
Good luck....
Apr 08, 2010 | Nokia Bluetooth Headset Headset
Can't end Bluetooth phone call with Zumo 550
I have a motorola phone, and it's fine.
I have paired the phone to the zumo, and the phone is set to connect to the zumo automatically.
Check the phone is set up this way, and all should be well.
Hope this helps.
Dec 24, 2008 | Garmin zumo 550 GPS Receiver
I had a similar problem when I first connected my Cardo Scala Rider set to the helmet. First off, make sure that the volume on the Zumo is set to 100% for BOTH guidance and mp3 functions. Then click the upper control on the Cado Scala to maximize the volume of the headset. When you've accomplished those two electronic hurdles, adjust the location of the speakers in the helmet - if location of the speakers is not optimized nothing you do with the electronics will have much effect. I typically run the mp3 volume at 20% and the GPS at 50% with the headset volume at halfway. My Cardo Scala unit is a Teamset and I sometimes have problems hearing my rider scream that I'm going too fast. I haven't bothered yet to tell her to keep the microphone closer to her lips.
Aug 07, 2008 | Garmin zumo 550 GPS Receiver
Garmin Zumo wired headset
I bought a wired motorcycle headset, which does works okay (below 50 mph), didn't like the wire so I switched to a BT helmet kit, manufactured by interphone, works like a charm.
May 03, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 bluetooth pairnig problem
Have you connected the device to the computer and run webupdater? Mine showed up with a bluetooth firmware upgrade. Bluetooth works fine, however, lost the functionality of the phonebook after the update. Sometimes you win sometimes you loose
Mar 28, 2008 | Garmin zumo 550 GPS Receiver
Connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
139 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
