Question about Samsung Computers & Internet
After booting up samsung NC10 error message saying windows could not start because following file missing/corrupt \windows\system\vgaoem.fon
    Genius:
  • 1,584 Answers
Ohh, sounds like you have corrupted / deleted a registry key. Boot from the off position and tap F8 key to see if it will boot into safe mode...if not reboot and tap the F8 again, when you see a black screen with white printing choose "last best known configuration that worked"
If that doesn't work then insert the windows disc if you have and reboot (Enable first boot as CD) then negotiate to "repair"
If still no go will need a format and reload windows.
You should have a recovery disc for it which you can load and follow on screen instructions to repair or reformat.
BEWARE if you format you will erase ALL data on the disc.
Posted on Oct 15, 2010
  • Samsung Master
  • 12,061 Answers
OK, try, Boot Up in SAFE MODE, press F8 At Boot up, quickly, select, Boot to safe Mode desktop, with networking... simply copy vgaoem.fon file from xp disc or from net, paste file into windows system folder, done.
OR You could simply perform a system restore back to another time BEFORE you had a problem, again start up in Safe mode, F8. but this time when the choice is given to choose safe mode desktop or system restore, choose system restore, when a calendar like thing is displayed choose a time PRIOR to this problem happening, follow instructions and before you know it your PC will be back.
My pc will not startup when i turn on it appears it crashed i have boot cd that i created. i tried to repair and it will not. im not sure if im doing it right.. i have windows xp.. the original error it...
Hello, Trace.
Here's some help regarding fixing this error. From HP Support:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=&product=89876&docname=c00188632
If you are still experiencing a problem, your created boot CD is probably faulty.
If it still is not working, depending on your hardware manufacturer, you may be able to access/run Factory Restore. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Please note that Factory Restore restores to the original settings and will wipe out anything that you have installed or saved on your PC.
Hope this helps.
Jan 23, 2010 | Computers & Internet
Vgaoem.fon
Hello there:
your problem is due to a missing or corrupt file this file is a key file that windows needs to operate.
please try this
Root of the issue
You might come across this error message and this behavior of Windows operating system due to missing or damaged Vgaoem.fon file. This is a key file for Windows operating system, which is required for Windows to boot up.
How to recover inaccessible or lost partitions
Follow the underwritten steps to sort out the issue:
  • Configure your PC to start from CD/DVD
  • Insert XP bootable CD and restart the system
  • Boot the system from CD and press R to start system in Recovery Console
  • At command prompt, type map and press enter
  • Type underwritten line and hit enter: expand CD-ROM drive:\i386\vgaoem.fo_ drive: \windows\system here CD-ROM drive is the drive latter of your CD Drive.
  • Type exit and restart the system.
If your system works properly, then the problem is resolved. In the else case use Partition Recovery Software to recover lost hard drive partitions and data. These tools are particularly designed to effectively scan the affected hard drive and retrieve all of the lost, missing and inaccessible hard drive partitions. These applications are quite easy and safe to use. i hope that this helps
best regards mike
Jul 22, 2009 | Compaq Presario 5000 PC Desktop
Windows could not start because the following file
For Windows won't start problem, I have met the same situation before. It was Windows Boot Genius to fix problem easily!
Jul 03, 2009 | Toshiba Satellite L25-S121 Notebook
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Missing or Corrupt
HP OMNI Book get error message of physical memory dump, screen goes blank. What is the problem? & How do i repair this...
Jul 31, 2008 | HP OmniBook XE3 Notebook
Gateway 9500 windows wont start
these are essential windows files you will need to reinstall windows in repair mode
set bios to boot from cd you will during boot up be asked to press any key to boot from cd press any key when widows loads all its drivers etc windows will ask what you want to do press r for repair and follow instructions
during setup windows will reboot a few times when it does do NOT press any key
Jul 27, 2008 | Gateway SOLO 9500 (7002886) Keyboard
Boot up issues
run cmos bios and configured boot device..first boot cd rom drive..
then reinstall/repair your os...
Mar 24, 2008 | IBM ThinkPad T21 Notebook
BENQ Joybook 2100
u need it to repair does afreinds have it burn a copy of it on 16 x or less ok
Nov 30, 2007 | BenQ Joybook 5000 Notebook
Computers & Internet Logo
310 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
