My Brother HL4050CDN printer showed that the 3 colour toners all needed replacing - I did this but the red screen saying 'End of Life' for the toners will not go out. I have switched off and on again but no luck.
    Scholar:
  • 192 Answers
Here is a trick.... Turn the printer off, but, you need to wait for 12-19 minutes, depending on the year of the Brother, but that will clear the chip, thus, allowing you to move forward.... PLEASE let me know if this does not lear it, we can dig a little deeper.... Guy
Posted on Oct 15, 2010
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
Brother HL-6050dn Toner Life End Message Tried covering the eye Tried Go-Set and changing to Nothing solution Still red message saying Toner Life End
I just got through this problem, The customer had a "refilled cartridge.
The Flag on the left side near the gearset of the Toner cartridge was not
brought back to the proper position, just undo the three srews and reset the flag.
works like a champ,. your welcome.
Dec 08, 2010 | Brother HL-6050DN Laser Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
Drum End Soon
You will soon need to replace the drum. Its considered a consumable just like the toner cartridges. You can purchase the drum anywhere that sells brother pruducts.
May 24, 2010 | Brother HL4040CN Laser Printer
Installed new cartridge and comming up machine won't regognise it saying tonner life end install new cartridge
To reset the sensor after installing a new toner cartridge follow these steps. 1. With unit powered On, open the front cover. 2. Press the “Options” key. Display will show “Replace Drum?” 3. Press “Start” key. 4. Press 1,0 . 5. Display will show “Accepted” for approximately 2 seconds. Then display will change to “Cover Open”. 6. Close cover and see if Toner Life End error message has gone.
Try this. We are Brother authorized.
Apr 15, 2010 | Brother MFC-7420 Laser Printer
My HL-2140 brother laser printer is flashing a red error
1>If the toner lite is blinking , it's mean the toner life near to end. In these case please replace the toner cartridge.
2>f the drum lite is blinking , it's mean the drum life near to end. In these case please replace the drum.
I hope it will help to solve your printer problem.
Feb 09, 2010 | Brother HL 2140 Laser Printer
We replaced the toner and it is still saying "toner life end replace toner cartridge." and we can't get it to print or fax or copy
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 23, 2009 | Brother MFC 7840W Printer
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
81 people viewed this question
k24674
jasbo
jasbo
