Question about Apple iPhone Smartphone
I have a syncing problem I can sync from Outlook 2007 Calendar TO my iPhone but not FROM my iPhone to my Outlook. Any events that I enter on my iPhone calendar will not show up on my Outlook calendar. Any suggestions?
  • 2,069 Answers
That is in your settings. recreate your profile with outlook because probably your initial Outlook Setup Wizard was not completed propery. also make sure you have installed the latest itunes.
Regards
Posted on Oct 15, 2010
Syncing my iPhone 5s with outlook 2007 and vise versa
Go to the Microsoft support site the instruction are there.
Jun 01, 2016 | Cell Phones
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
Can I sync ipad with outlook? i'm using outlook 2007 and I really would like to sync it with my new ipad.
Hi
I had the same problem, outlook on ipad or syncing ipad with out look is very easy, just follow those few steps, Good luck!!!
I'm using iTunes in order to sync ipad and outlook, make sure your itunes is up to date (help ---->"check for updases") .
How to Use iTunes to syncYour iPad With Outlook Calendar.
* Connect your iPad to your laptop or desktop using the cable that you got with the ipad.
* iTunes will launch in the PC automatically.
* You'll need to find the itunes source list, choose "iPhone" and click on "Info" tab and then "Sync Outlook calendars" option.
* Notice in the lower right corner of your screen the "Apply" button. click on it.
Now your computer is synced with the ipad and the outlook!
Feb 11, 2010 | Apple iPad 32 GB WiFi Tablet PC
Transfer calendar info from Tungsten/E Palm to iphone 3GS
The best way is to transfer the Calendar and Contacts to Outlook. The iPhone can then be synced with Outlook.
Unfortunately, tasks and memos do not transfer. You will need to find other 3rd party apps that are supported on the iPhone and transfer your data to them.
Two examples are:
1. Evernote - This is good for memo. You can export your memos and then import them into Evernote. unfortunately, when I did this, it was a bit tricky. I even had to write a little PERL script to create the format that it wanted.
2. RemembertheMilk - this is a todo application
Jan 03, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
I have read all the msg boards and am still not able to sync my iphone 3gs to outlook. does it have anthing to do with running Vista? I used to work then notice that it changed
Vista shouldn't have anything to do with it, unless your using a 3rd party software to connect it.
First thing, Update iphone to latest version.
Update outlook 2007 using windows update.
The resent update to the iphone firmware and itunes fixed the problemof things not moving from iphone back to outlook.
BEFORE the fix for the iphone , to get an event to show up back in outlook , you would need to make it a recurring event on the iphone starting and ending on the one day ...
to test if thts the problem you have , make a new calendar event in your phone and make it recurring, starting and ending on the same day.
sync, then check outlook.
Before this update to get things working I needed to do the following...
1) backup your outlook .PST file. 2) rename and move the existing pst file, and create a new one.. 3)import the contacts 4) import calender events, (not recurring ones) 5)sync.
Taken from: stu @ http://forums.whirlpool.net.au/forum-replies-archive.cfm/1044679.html
Oct 19, 2009 | Apple iPhone Smartphone
My boss wants his Microsoft 2007 Outlook Calendar on his Iphone.
http://support.apple.com/kb/TS1347
i googled your question and found the apple page. in case it doesn't load or is blocked, run the setup wizard for outlook first, then sync after because outlook will not sync unless it has made the file first
Jul 02, 2009 | Computers & Internet
Sync iphone 3g calendar w/outlook 2007
In itunes go to syncing options and make sure contacts and calender are selected! then resync! hope this helps! Merry christmas!
Oct 03, 2008 | Apple iPhone Smartphone
Sync Outlook 2000
You can transfer your contact list, but not your calender. Here are the steps to take to successfully transfer your contact list from outlook 2000 to the iPhone:
1. In Outlook, export your contact list as a Comma Separated Values (Windows) file
2. In windows accessories, launch Address Book
3. Import into Windows Address Book the file you created in step one
4. Now back in iTunes, sync your iPhone contact list with Windows Address Book
You contacts should come over intact.
Sorry, but there is no solution that I know of to import Calendar events.
JAF
Oct 19, 2007 | Apple iPhone Smartphone
Sync iphone to outlook
Only way i could get any sync was first strangling the cat,wrapping its limp body round my neck,then getting two pieces of celery of equal length.Soaking these overnight in a mixture of lemon juice and urine.Drink the juice at 2 minutes past twelve on a full moon,insert the celery where the sun dont shine and whilst hopping on one footand circling the p.c with the iphone balancing on my forehead.First few times no joy then bingo synched right off.
hope this helps
Jun 30, 2007 | Apple iPhone Smartphone
Calendar Sync issues with Treo 650
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
Sep 11, 2005 | Palm Treo 650 Handheld
Apple iPhone Smartphone Logo
65 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
