Question about Philips Magnavox TS3260C 32" TV
Phillips tv when on channel 1 if I push the program up button instead of turning to channel 2 it jumps to 700.all the stations are tuned in
  • 998 Answers
Try to check your auto tuning it is activated disable it.
Posted on Oct 15, 2010
I have and older unit a pioneer VSX 3800, how do you program the radio channels, is there a manuel for these unit i can get sent to myself
Hi.
You have a digital display pioneer receiver and you would like to know how to store radio stations.
  • first tune your radio to your selected radio station
  • next see if the receiver has a button marked memory, and it should have buttons marked 1 2 3 4 5 6 etc
  • After you have tuned in to your selected radio station, if it has a button marked memory,
  • Press the memory button, then press and hold 1 for a few seconds and that should store your selected radio station to preset 1
  • Next, tune in to another radio station and store it by pressing memory then 2 and that should store it in location 2.
  • If your Receiver doesn't have a button labelled memory, and simply has the store 1-6 etc buttons then ,
  • Tune in to your radio station , then press and hold 1 for a few seconds, it will probably flash a few times until its stored in that location 1
  • Next, tune in to another radio station, then press and hold 2 and that should store it in location 2.
  • repeat.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Pioneer Audio Players & Recorders
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
I have just purchased two srp2003/27 remote controls..i cannot enter set up mode because neither one of my tv's has a channel 1....the lowest one goes is 3 and the other 2..what can i do?
All TV sets go as low as channel 1. Its just that your tv has been preset to skip certain channels because no station was stored on them. All you have to do is go to the unit and manually change the stations with the program button.
If on the other hand this does not work try going through the menu button like you want to tune a new station and after tuning a station select it to be saved in position 1 Then you can acces channel 1.
Hope this solution has been helpful?
Sep 23, 2010 | Televison & Video
How to program channel without remote
First be aware that if you are using an antenna this television has an analog tuner which is no longer capable of receiving any digital signals which is the only channels being broadcast as of June 2009. If you have a cable or satellite receiver then here is the procedure for auto programing your channels. Make sure your active cable/satellite is plugged into Ant 1 (Antenna 1) on the back of your set.
On the front panel push the menu button until the "Channel" is highlighted. Then push either the plus button or the down button to highlight auto program.
Once that is done push plus or up and the set will automatically tune in all the available stations
Zashiban
Jun 04, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Do not have manual. Need to program tuner channels and clock.
For clock turn key on and stereo off. Press and hold the function button for 3-5 seconds. the clock should appear with the hours flashing. Use the up-down buttons to set hours. Push the right button to set the minutes. Now turn on the stereo with the source (or power) button and your done!
Remember key on stereo off. hold function, the rest will become second nature once you've done it a few times.
Tuner pre-sets are super easy. Tune to the station you want and then just hold the # button (1-6) that you want that station on for about 3 seconds. The channel your on, (e.i 104.9) will flash a couple of times and then stop flashing. When it stops flashing it's in the memory. Tune your next channel and hold # 2,3,4,5,6, If 6 isn't enough push BAND and your on FM-2 with 6 more pre-sets, Push it again for FM-3 with 6 more presets. Push it a 3rd time for the AM band with 6 pre-sets and one more time to get back to FM-1.
Apr 07, 2010 | Pioneer DEH-P3100 CD Player
Manual stolen when car was vandalized, need to know how to set clock and radio stations in 1994 Ford Tempo please
setting stations on Fords are easy,put it on the station you want to program and push the channel button in and hold for about 2 seconds then it should flash,now the channel is set..now for the clock,with the key on and radio turned off,press the clock button,then press the seek or scan forward or reverse to adjust the time,then hit the clock button again to make sure it sets.
Oct 22, 2009 | 1994 Ford Tempo
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
--axoplasm
Nov 02, 2008 | Televison & Video
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Philips Magnavox TS3260C 32" TV Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
