Internal hard drive add-on question
I have an older WD IDE hard drive that needs upgrading (WD400BB-53CAA0). What are my options as to the type of hard drive I can add, if I want to keep this hard drive (it's fine, just full). EIDE? Ultra ATA? I think that I cannot use a SATA disk, but am just not sure what I *can* get.
I am running XP SP2.
  • RG-lfp Jun 04, 2008
    Don't know what the motherboard model is.  The computer is a Gateway desktop, 500XL.  It has one short slot open.  There is one HD (the one I want to add to), DVD, writeable CD, and 3.5" drives.  The HD cable only has the master- the slave socket is open.  As I said, it is a 40 Gb IDE (PATA) drive.  Since the IDE isn't SATA, I don't think I can add a SATA to the system in the current config.  Thus, what are my options as to drives to use, w/o adding a SATA card- or should I go ahead and get a SATA card.  If so, what is the benefit?  What is "ultra ATA"? Can I use that in this config?
    Is this enough info?  Thanks!
  • CCWILL Jun 12, 2008
    I have a conpaq 1.3GZ with a 40GB PATA(ata) hard drive. I want to remove this and replace with a SATA. I believe I need a controller or adapter from IDE to SATA. Am I right? Thanks for your time and knowledge.
    Sergeant:
  • 369 Answers
CAN U PLEASE TELL ME THAT WHATS THE MOTHERBOARD MODEL IS IT DESKTOP OR LAPTOP IF DESKTOP U CAN USE SATA HARD DRIVE BY USING A SATA CONTROLLER CARD if just u have a pci slot empty if yes tell me so i tell u the model number t take a card and fix it your self...
thanks
Posted on Jun 03, 2008
Wd400bb 75jhco
No it won't they are different connections.buy the adapter off eBay about 5 GBp for Sat IDE and laptop all in one to usb
Sep 01, 2014 | Computers & Internet
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
What type or brand of hard drive do I have to get to install in Acer AM5641 Desktop ? I want to upgrade to a 1 tb hd.
You currently have a 320GB 7200-rpm SATA II hard drive, with 8MB cache install on a base package of your make and model of computer. I would recommend a hard drive like Samsung Spinpoint F4EG 2 TB Internal hard drive. You can find it roughly for $70.00 - $90.00 at online stores like amazon, new egg, etc.
I hope this helps.
Jun 30, 2011 | Acer AM5641-B5660A Desktop PC & Monitor...
I have a gateway and am trying to replace my current hard drive with the Western Digital Caviar WD400BB 40 GB Hard drive . I currently have 2 maxtor drives in that are op as 1 partition. I hook it up but...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Apr 01, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
What is the slave patern for 500 gig hard drive
hope this helps
Dec 10, 2010 | Western Digital WD Scorpio Blue WD5000BEVT...
Upgrade my Dell Dimension 4400 Service Tag 43L5811
You can upgrade to practically the maximum available amount of harddrive space as long as the new drive is IDE. The following picture shows the drive you require:
A guide to replace a hard disk for this PC is available here.
As a rule of thumb, you should buy the maximum size hard disk you can afford as it improves the performance.
You can choose from any brand but choose the one with maximum warranty.
PS. There is no need to go into any kind of numbers; just ask the vendor to give you a certain size IDE hard drive eg a 250GB Western Digital IDE hard drive.
Mar 08, 2010 | Dell (078FN) ( 078fn ) 9.1 GB...
Given E-Machine 366I2. Will not take new hard Drive
Shouldnt think it was the cables since you got as far as you have. Could be a problem on the drive and you might want to do a low level format to make sure. Drive type should not matter. Western Digital has a low level format utility on there site. wd.com
my other thought is that for some restores you have to have the exact components present that originally came with the machine. so, unplug everything but keyboard, mouse and video. put back to original amount of memory.
use a windows disk to do restore from scratch instead of restore disk. good luck.
Jan 02, 2010 | Computers & Internet
Iwant to put a 500 gig harddrive on 4 yr old 741gx-m motherboard
Certain older motherboards do only have support for certain sizes of drives. It depends on how the motherboard references the various sectors on the hard disk. So your friend wasn't too far off.
But this restriction applies to OLD motherboard. Anything made in the last 8 years is fine. The 741GX-M is more than modern enough.
The 741GX-M uses IDE as it's interface for hard drives, so make sure you get an IDE 500gb hard drive. Also make sure that your hard drive's jumper settings are correct. Your first hard drive is the master. Second one is the slave, and the jumpers should reflect that.
As far as operating systems go, Windows 98 has a limitation of 128gb, but ONLY because scandisk will fail on anything larger. 2000, XP and Vista handle 500gb using both the NTFS and FAT32 filesystem (but ntfs is better). All linux distros can handle 500gb using the ext2/ext3 filesystems.
If you do run into any problems detecting the hard disk, make sure you have the latest bios for your motherboard. That's just about the only real problem you can run into.
Dec 24, 2008 | EliteGroup 741GX-M Motherboard
Hard drive replacement
You needed to know if you HD is an IDE ATA or an S ATA. The speed is about the same on all of them unless you go for a realy fast HD but they are noisy. You cable should work with your hardware if that is it's purpose. After you swap, do not attach the old hard drive back w/o reformatting it. If you cable and software does not work the their is other software that works very well to upgrade HD's. I personally use Acronis True Image. SOme upgrade HD's come with the software to upgrade with such as WD or Seagate.  I have a 1 Terabype in my computer as an extra drive but keep the OS as is and only place my data on the larger drive.
Dec 14, 2008 | HP Pavilion m200y (516673) PC Desktop
Upgrade Possible?
Hey Al,
The internal Drive is a standard 3.5 inch IDE 7200RPM unit. you can indeed upgrade this to a 1TB drive as long as it's IDE wether 2.5 or 3.5. Luckily when Lacie was originally offering these drives you could get these in 1TB, so that won't be an issue.
Ciza
Oct 28, 2008 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
