Question about Optoma Office Equipment & Supplies
I have an Optoma H31 projector that powers on, but the lamp doesn't light. All fans work. The voltage at the lamp measures around 250 VDC at startup but quickly goes to 0 and then the fans come on. After a few seconds, the green power light flashes like it's ready to be turned on. What could be the fix for this?
  • 2 more comments
  • jnovogradac Oct 15, 2010
    I'm not sure of the age. I imagine it is a few years old though. I bought it on eBay and it said it should work, but it didn't. I tried the lamp in another projector and it lit up fine so I know the lamp is good.
    No it hasn't.
    I have an Optoma H31 projector that powers on, but the lamp doesn't light. All fans work. The voltage at the lamp measures around 250 VDC at startup but quickly goes to 0 and then the fans come on. After a few seconds, the green power light flashes like it's ready to be turned on. What could be the fix for this? I tried the lamp in another projector and it worked fine, so it's not the lamp.
  • jnovogradac Oct 18, 2010
    The light doesn't light at all. I put the light in another projector and it works fine in it. I also put a known good light in the H31 and it didn't light either.
    If the projector doesn't come on (light) how can you set the multimedia inputs?
  • 6,826 Answers
When the voltage goes to 250 vdc does the light light at all? Does the lamp itself, when removed, have continuity? If not, then the lamp may need replacing.
Or, the mode of the projector needs to be set so that multimedia inputs are accepted.
Good luck on this repair.
Posted on Oct 15, 2010
  • 2 more comments
  • Duane Wong
    Duane Wong Oct 18, 2010
    I know that sometimes the projectors have to be turned on with the input active from a laptop or a computer that you want to project an image from.
    I used to observe someone using one where sometimes the projector lamp would work and sometimes it wouldn't even with the input active. I can't remember the brand though. But, usually that one would power up and show an initializaiton screen before going dead, occasionally.
    I looked up the following troubleshooting on the Optoma site for the H31 unit:
    http://marketing.optomausa.com/PDFs/user...
    Problem: No image appears on screen.
    4 Ensure that all cables and power connections are correctly and
    securely connected as described in the “Installation” section.
    4 Ensure that the pins of connectors are not crooked or broken.
    4 Check to see if the projection lamp has been securely installed.
    Please refer to the “Replacing the Lamp” section for more
    information.
    4 Make sure that you have removed the lens cap and that the
    projector is powered on.
    4 Ensure that the “Hide” feature is not turned on.
    Problem: Partial, scrolling or incorrectly displayed images
    4 Press “Re-Sync” on the Remote Control or Control Panel.
    4 If you are using a PC:
    For Windows 3.x:
    1. In the Windows Program Manager, double click the “Windows
    Setup” icon in the Main group.
    2. Verify that your display resolution setting is less than or equal
    to 1280 x 1024.
    For Windows 95, 98, 2000, XP:
    1. From the “My Computer” icon, open the “Control Panel”
    folder, and double click the “Display” icon.
    2. Select the “Settings” tab
    3. Click on the “Advanced Properties” button.
    If the projector is still not displaying the entire image, you may
    need to change the monitor display that you are using. Refer to
    the following steps.
    Troubleshooting
    If you experience trouble with the projector, please refer
    to the following information (listed below). If the problem
    persists, contact your local reseller or service center
    immediately.
    Appendices
    English 28
    Appendices
    4. Verify the resolution setting is less than or equal to 1280 x 1024
    resolution.
    5. Select the “Change” button under the “Monitor” tab .
    6. Click on “Show all devices.” Next, select “Standard monitor
    types” under the SP box; choose the resolution mode you need
    under the “Models” box.
    7. Verify that the resolution setting of the monitor display is less
    than or equal to 1280 x 1024.
    4 If you are using a Notebook PC:
    1. First, follow the steps above to adjust resolution of the
    computer.
    2. Switch the Notebook PC display to the “external display only”
    or “CRT only” mode.
    4 If you experience difficulty changing resolutions or your
    monitor freezes, restart all equipment including the projector.
    Problem: The screen of the Notebook or PowerBook computer
    is not displaying a presentation.
    Some Notebook PCs may deactivate their own screens when a
    second display device is in use. Each has a different way to be
    reactivated. Refer to your computer’s documentation for detailed
    information.
    Problem: Image is unstable or flickering
    4 Use “Phase” to correct it. See page 23 for more information.
    4 Change the monitor color setting or the frequency on your
    computer.
    Problem: Image has vertical flickering bar
    4 Use “Frequency” to make an adjustment. See page 22 for more
    information.
    4 Check and reconfigure the display mode of your graphics card to
    ensure compatibility.
    English
    29
    Problem: Image is out of focus
    4 Adjust the focus ring on the projector's lens.
    4 Make sure the projection screen is between the required distance
    4.6 to 39.4 feet (1.4 to 12.0 meters) from the projector.
    Problem: Image is reversed.
    4 Press “Menu”, then select “Display” to adjust the projection mode.
    Problem: Lamp burns out or makes a popping sound
    4 When the lamp reaches its end of life, it will burn out and may
    make a loud popping sound. If this happens, the projector will not
    turn back on until the lamp module has been replaced. To replace
    the lamp, follow the procedures in “Replacing the Lamp” page 30.
    Problem: LED lighting message
    Message
    Power LED
    Green Orange Temp LED Lamp LED
    Standby State
    (Input power cord) Flashing Off Off Off
    Lamp lighting On Off Off Off
    Power on On Off Off Off
    Power off Off On Off Off
    Error (Lamp fail) Off Off Off On
    Error (Thermal fail) Off On On Off
    Error (Fan lock fail) Off On Flashing Off
    Error (Over Temp.) Off On Flashing Off
    Error
    (Lamp Breakdown) Off On Off On
    Problem: Message Reminders
    4 “Lamp may fail soon! Replacement suggested!” will be shown
    about 10 seconds when lamp life is going to deplete.
    4 “Over temperature” will be shown when the system temperature
    is over heat.
  • Duane Wong
    I'm sorry, the formatting of the appendix of the manual was lost on copying and pasting.
  • Duane Wong
    The above link goes to the manual where I got the troubleshooting information.
  • Duane Wong
    information.
  • 712 Answers
How old is the equipment?
  • Sebin Punnacheril
    Sebin Punnacheril Oct 15, 2010
    So haven't it worked since the day you bought it from eBay?
  • Sebin Punnacheril
    So why don't you consider returning it and ordering a new one from the same seller?
Projector
What is the model number?
Nov 23, 2013 | Optoma Office Equipment & Supplies
Optoma HD20 DLP Projecto problem
this is not an hd20..... nor is it the right kind of capacitor that an hd20 needs...........
Aug 21, 2012 | Optoma HD20 DLP Projector
I have an Optoma DS303 projector. It stopped working. We replaced the lamp and it worked for about 3 hours and then when we tried to turn it on again, it won't fire up. Sometimes if I hold down the...
Check the voltage at the lamp input from the ballast after connecting projector to mains supply. (Warning: Do not switch on the projector while checking the voltage. It will damage your multimeter) The lamp connection shall be removed. If the voltage is around 60 to 80 volts AC, then your ballast is OK. Check for fragments inside the lamp.
sonsunny
Jun 14, 2011 | Optoma DS303 DLP Projector
Optoma h31 stopped suddenly. I replaced the bulb, but the power button isnt flashing green, and I cant turn the unit on.
The little metal plate on the projector next to the bulb housing is not fully depressed (pressed down). The plastic cover is suppose to have a plastic piece protruding from it which is to depressed the metal plate when the cover is placed back on. If the metal piece is not pressed down, the projector will not light.
Feb 10, 2011 | Optoma H31 HOME THEATER PROJECTOR...
I just put a new bulb in my Optoma H31, but still get Lamp Fail
have you check that the bulb you installed is the right bulb for your unit?
have you check by replacing your bulb it correct position?try to unplug the power cord and lug it again and turn on.
Oct 09, 2009 | Canon RS-LP02 Projector Lamp for LV-X6
Optoma h31 was unable to power up
It can have two problems. One is that the lamp has gone out and needs replaced. Refer to your troubleshooting section in your manual. Also can be bad capacitors in the power supply circuitry or Voltage Reg. IC. Either should be left to competent repair individual.
Jun 24, 2009 | Optoma H31 Multimedia Projector
Optoma H31 - Turns itself off !
sounds like the projector lamp to me. the rated hours are always up to the published hours and never "this is what you will achieve." I would suggest getting a lamp as you will need one shortly by the sounds of it. In many cases the projector does this as it is programmed to protect itself from the lamp shattering inside the projector. Let me know if you would like a quotation for a lamp as we ship internationally. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Mar 28, 2009 | Optoma H31 HOME THEATER PROJECTOR...
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
679 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
