Question about HP LASERJET P1005 Printer
My printer print the whole paper blank what can I do to fix the problem
    Genius:
  • 1,584 Answers
Use the printer software to do a "head clean" or it may be out of ink.
Posted on Oct 15, 2010
Sounds like it's printing, ejects the paper and it is blank. Help!!
Try the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, re-insert both cartridges.
  6. Close the printer.
  7. Load some paper in the feeder.
  8. Try to print again to verify that the problem is fixed.
Let me know how it goes.
Dec 05, 2011 | Lexmark X2500 All-In-One Printer
Printing is blank...no ink coming out on to paper
Your printer cartiage will be out of ink.
Or it will be dry cause of not used from long time.
Change the printer cartiage may fix this problem.
Thanks.
Oct 09, 2009 | Office Equipment & Supplies
My printer giving blank paper in epson lq2090 dot matrix printer
Either your ink ribbon is worn out or it is broken, or it is put in wrong, or your print head isn't working. Pull the print head the whole way toward the paper (With the adjustment lever) and run a test sheet. Look at it closely. If you see imprints, it's the ribbon. Id you don't, it's the print head.
Sep 03, 2009 | Epson Office Equipment & Supplies
5610 printing just a line in the middle of the page, else blank!
wow..I could be the FIRST..I am impressed..NOT!
check to see if there is ink, by blotting the print head on damp paper towel.
otherwise..delete and reinstall the printer. could be a software problem.
Apr 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Select print and paper is blank - all cartridges have ink
dear friend
the thing that you have changes is ink tank, not the whole unit
this problem is with all the machines which have separate ink tank and head assembly
generally head gets blocked and users keep on changing the ink tanks
friend you have to change head also to get your machine working
thanks
Apr 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Paper jam
At the back of the printer... open the feeder door and slowly remove the jammed papers.... put it back and put some paper in the tray and press resume button... this will continue printing the remaining print jobs.
good luck... happy FIXYA...
Aug 20, 2008 | HP DeskJet F380 All-In-One Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
HP 5550 Print issue
When you removed the jammed paper , the jam paper sensor was not reset or positioned correctly. The reason the machine was sending two pieces of paper thru at once was probably due to the paper feed sensor. A lot of H'Ps do this. Try re-aligning the tray and if you pulled the paper out and heard a grinding noise, the whole feed unit is probably out of time.I would only re-install the software as a last resort, since your problem was caused by hardware, not software. Scrivitron
Jun 20, 2007 | HP DeskJet 5550 InkJet Printer
HP LASERJET P1005 Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
