Question about Garden
What would cause a pressure washer to cut off after you pull the handle to get the water started
We used power washers for years
When you pull the trigger, the engine is supposed to accelerate because the back-pressure on the pump is released.
The back-pressure is why you're supposed to keep the gun trigger open when starting the engine. It sounds like you're starting the engine with no water passing through the gun.
Inspect the exhaust port >> if exhaust is clogged with carbon or dirt, then the engine will not run at high speed.
The problem may also be cause by a rusted choke lever. If you notice when a small engine accelerates, the choke lever moves up as the carburetor demands more gas.
Start the engine with water passing through the gun >>> move the choke lever a little bit at a time and see what happens. Keep water going out of the gun. When the surfaces are cool, spray WD-40 on the lever and see if you can free it up. WD-40 is extremely flammable.
If your engine will not fire at all by starting with water passing through the gun, then your gas supply might be limited or your carburetor gummed up. Pull off the rubber gas line that connects to the carburetor and see if gas flows.
Next, pull off the air filter and see if the machine runs good without air filter. You may have clogged air filter.
While the carburetor is exposed, spray WD-40 into carburetor. See if you can get engine up to full throttle while spraying WD-40 into carburetor. Keep spraying the WD-40. Keep the water flowing out of the gun.
If the engine throttles up all the way on WD-40 but won't run without it, then your carburetor is probably gummed up.
Our old power washer won't run with the choke set at full throttle. We just got into the habit of leaving the choke alone. We'd pull off the air filter and spray WD-40 into the carburetor so the engine would spark healthy without messing with the choke at all. And we kept the choke about 2/3 open all the time.
Posted on Oct 15, 2010
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Starter cord want pull on husqvarna model 020524 pressure washer, not even with pressure of water off
hold the trigger down on the spray gun and then try, the pressure is built up in the pump - the pump can't turn against the back pressure.
Dec 27, 2014 | Husqvarna 3300 PSI 3.2 GPM Gas Pressure...
WHAT COMMON FAULT CAUSES THE PRESSURE WASHER TO CUT OUT WHEN PULLING THE SPRAY GUN TRIGGER
Lack of water preesue can cause this, how long is the hose to the washer, are there any kinks and what is your water pressure like generally.
If there are no kinks try shortening the water feed hose
Sep 13, 2014 | Garden
My pressure washer starts if handle is pulled releasing water but when handle is disengaged no longer spraying water the motor shuts off, what could cause this on my new unit.
you have a faulty unloader valve have it inspected for possible obstruction in check valve which is normally located where you connect the high pressure hose.
Aug 17, 2014 | Garden
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when the...
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
Jun 16, 2014 | Karcher PSI Electric Pressure Washer
While using our troy bilt 2550 preassure washer it cut out and I could not pull the start cord. After a while I could start it when the water was not connected however when I connect the water it will not...
Try connecting the water but hold open the trigger. While holding open the trigger, try to start the pressure washer. That works for me.
Feb 21, 2014 | Garden
Why don't i have any power on starting washer?
Could be in the spray handle and or nossle. Many years ago I brought 1 of these units ( Not by Bosch ), and the problem turned out to be in the spray handle...
Jun 05, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
With pump removed engines runs fine. When new pump is installed it is very hard to pull with water flowing but will not start. Engine was just tuned up late year.
Chances are that your new pump is generating good pressure. Because of this, the engine is trying to turn over against the pressurized system. Try pulling the handle on your wand when pull starting the engine to see if this eliminates your problem.
Jul 01, 2010 | Briggs & Stratton Prosumer 20324 Gas...
New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Apr 25, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Garden Logo
579 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
