Question about HP Compaq WF1907 Monitor
MY MONITOR SHOWS: VGA No signal DVI No signal then shows: Check Video Cable Then: Monitor going to sleep
    Genius:
  • 1,584 Answers
Try another cable, borrow one, then try monitor in another PC / laptop, if it works then either the software settings for the sleep mode are on or it may be a faulty video card.
Posted on Oct 15, 2010
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
I loaded Windows 7 and now when I turn on the computer, the monitor says DVI input no input signal and goes to sleep. Can you help?
Do you have the correct driver loaded? Are you using DVI output on the computer? Is there a VGA output? If so, try using a VGA cable while you troubleshoot the video issue.
May 11, 2011 | HP w2207 Monitor
I have a 19 inch Gateway HD monitor. The model number is LP1925. When I boot up everything is normal. However, after about 5 minutes the screen goes black. I can't get the picture back unless I pull out...
I see that this monitor has a DVI input, in additon to the VGA input. I suggest getting a suitable cable to use the DVI input, to see if the fault replicates. If it doesn't, you have identified the problem - an issue with the analogue signal processeing circuitry in either the monitor or the computer. The monitor's auto sleep analogue circuitry, for example, may not be sensing a signal, and going to sleep. BTW, if you use a DVI-DVI cable, you avoid the video signal ever going through an analogue stage, and the image will also be purer.
Dec 16, 2017 | Gateway 19" Widescreen Flat Panel TFT LCD...
Monitor remains blank and says there is no signal. Then it says it's going to go to sleep. It also says check DVI. What's that? The monitor worked perfectly when I installed it a couple of days ago.
Well, it not getting the video signals from your PC. Are you using VGA or DVI cable for the video connection to the PC. Does this monitor work OK with another PC?
Please post back what you find.
Jan 15, 2011 | HP Computers & Internet
Moniter keeps turning off saying no video imput
Hello and Welcome to FixYa!
Check that the Input signal cable is properly inserted in the VGA socket. Secondly the Primary VGA is properly giving display signals to the Monitor/LCD. Because there are cases in which VGA is the bottle neck of the trouble you are facing.
Cross check and update me with the status,
Best of Luck,
Do RATE the solution, If found Helpful,
Concerned.
Jun 13, 2010 | HP vp17 Monitor
Can't get signal for VGA nor DVI cables... Cables are fine... Monitor is always going to sleep and I can't see anything from PC
if pc boots up your video card is shot you will have 2 replace it this happens alot on hp compaq I dont no why. you might want to check if there has been a recall on the video cards from hp website
Apr 06, 2010 | HP Compaq WF1907 Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
HP Compaq WF1907 Monitor Logo
817 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
