Question about Dyson CRO1 Front Load Washer
I have a Dyson CRo1 - split drum washing machine. currently the machine cannot be put into programme as it is indicating the outer door is open. When door re closed - same indicator appears. Door lock was repaired approx 18 months ago - it would appear to be the same problem. Require details of price to attend and repair at the very earliest opportunity. Or Advice on who best to contact.
  • 1894 Answers
SOURCE: Dyson CRO1 F11 Fault
normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
until what cycle does this unit proceed?
Posted on Jul 26, 2008
jonniewalker
  • 1031 Answers
SOURCE: dyson cro1 fault f11 came up after interupted power suply
The F11 fault is a fuse blown on the circuit board.
Apparently this fuse failing can blow the board so you may have to change the board if needed. The board is located at the back of the machine so you need to take the back off, unplug the board, change the fuse which you can buy at Maplins and put the board back.
If it works fine, if not then you need a new board. Hope this helps you.
First make sure machine is turned off.
Second press & hold temperature button .
Thirdly press the on button & hold at the same time as the temperature button.
Fourthly release the 2 buttons at the same time .
Fifthly press the soil button .
Sixly turn machine off then back on & F11 message saying fault F11 must disappear.
if not try this process once again. if the error is not cleared then you will have to do as i have said you earlier.
Posted on Jan 18, 2009
SOURCE: I live in Portugal and my Dyson Cr01(bought in
I have decided that was time to end my Dyson induced headaches, and i actually dismounted the machine into single components.
Every component except for the tub and drum assembly is in good working condition, and available for whoever needs them, for a very cheap price. From cables and panels to electrical and mechanical components, every part of my Dyson CR01 ready to ship, whoever is in need anything just get in touch with me to my gmail adress (luismanuelantunes@gmail.com) and we will arrange a good deal.
I want to get rid of all of it before the end of the year, if possible, for space reasons.
Posted on Dec 17, 2009
SOURCE: dyson cro1 stuck in self clean mode??any ideas
hiya did you have any luck with your self clean problem? I only ask cus i have the same problem kind regards Dave
Posted on Apr 03, 2010
SOURCE: machine saying close outer door but its closed
I'm not an washing machine engineer but I do tend to do all my own home repairs - had to fix this fault this morning,
Quite easy to fix as long as there are no broken parts in the interlock and the solenoid isn't jammed.
UNPLUG FROM MAINS
Remove the top - 2 Philips or flat blade screws - pull backwards.
Remove front door - large flat blade inserted into gap in lower door hinge at back and gently twist to widen gap while pulling the door forward at bottom.
Remove 4 torx type screws (not sure what size) and 2 long torx screws from behind the hinge.
You may want to remove the coin trap door now - it makes the job of removal and refitting the front panel easier. Remember to put a tray underneath!
Unplug the ribbon connector for the front panel from it's socket and the clips - unplug the little pipe from the middle of the front panel.
Gently lift the front cover pulling the bottom edge forward a bit to ease removal. It is not necessary to fully remove the front panel so you can leave the mains switch connected.
Unhook the emergency release strap from the pivot arm.
2 Torx Screws above and below the door latch hole secure the latch assembly. Unplug the latch from a socket past the little foam block on the front - just inside the machine.
You now have the latch. Operation is quite obvious. The door loop pushes an angled plate that swings a hook into the loop. The solenoid when activated pushes a bar down to lock the hook in place and push down on 2 micro switches wired in series as the interlock.
To strip down the assembly unplug the micro switch plugs and push a small screwdriver into the top and bottom catches.
You can now lubricate the latch and check the function of the micro switches using a meter. They a easily replaced if you can find the correct type. (Unofficially - for a home repair - if one is not working you could always bypass one - but I wouldn't condone that obviously)
If you are careful enough - the operation of the solenoid and latch can be checked and observed by plugging the unit back in and pushing the door loop into the latch - be careful of the exposed wires etc - not sure what voltages are there!!
If it's unservicable then a replacement is about £35 online.
Reassemble in reverse - nothing to point out and is quite straghtforward. Dont forget the little pipe on the back of the control panel - it's easily missed.
Hope this helps.
Darren
Posted on May 31, 2010
Drum is not turning
Dyson Flowcheck CRO1 Front Load Washer "drum seized ...
www.fixya.com > ... > Dyson Flowcheck CRO1 Front Load Washer
Dyson Flowcheck CRO1 Front Load Washer, drum seized related issues. Get free help, solutions & advice from top Dyson experts.
Aug 08, 2015 | Dyson Memory CRO1 Front Load Washer
The soap drawer on my dyson washing machine wont close properly
my cr01 memory did suffer from this problem
i found the hot water entering the machine was too hot and the outer part of the soap dispenser had become distorted.
the solution is a replacement outer part.
bear in mind Dyson will be no longer supplying parts or support for the washing machine at the end of this year
Sep 19, 2012 | Dyson Flowcheck CRO1 Front Load Washer
Hi just had dyson fit a new pump door lock and drawer but machine is not contrarotating now is this a fault or a dyson modifacation
Dyson engineers turn off the contrarotation on purpose to preserve the drum bearings as they aren't available anymore, its a firmware update they do automatically when they service the machine.
May 30, 2011 | Dyson Memory CRO1 Front Load Washer
Outer door is open but machine thinks it is closed cant now close & machine also thinks it is on a cycle - which is isnt. I have tried to cancel it but it will not cancel because the door is not shut!
Sorry to hear you're having difficulties with your Dyson Contrarotator. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone, and provide the information and assistance you need.
You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Mar 01, 2011 | Dyson Flowcheck CRO1 Front Load Washer
Wont start keeps on saying close outer door
your door switch is broken. needs to be replaced
Sep 22, 2009 | Dyson CRO1 Front Load Washer
Outer door dyson washing m/c
try turning screw under detergent tray?
Sep 05, 2009 | Dyson Memory CRO1 Front Load Washer
Dyson cro1 stuck in self clean mode??any ideas
Apr 05, 2009 | Dyson Memory CRO1 Front Load Washer
Dyson washing machine memory modle
open both doors, on inside of inner door are 2 brass screws,
remove these and pull handle off,
to replace just squeeze locking mechanism through same hole and replace 2 screws .easy.
May 16, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Dyson CRO1 Front Load Washer Logo
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
