Question about IBM APTIVA (61H2631) Motherboard
I cannot find the power switch?on my ibm computer.
  • 62 Answers
Check user mannual but see this also for pannel connectori cannot find the power switch?on my ibm computer. - 85d7f26.jpg
Posted on Oct 15, 2010
I have a IBM net vista and the power button does not work
That IBM Netvista should have a model number on the back.
This tells me if the computer is so old it uses an AT power supply, or an ATX power supply; as modern computers do.
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
The old AT form factor of Power Supply, used the above type of main power cables.
The Power On switch was usually connected to the Power Supply.
A separate cable went from the front of the computer, connected to a Power On button, to the Power On switch on the Power Supply.
Or a separate Power On switch was mounted to the Power Supply, and a metal rod pushed against it.
The metal rod pushed by a plastic Power On button, in the front of the computer.
The ATX form factor design uses a Soft Power On circuit.
When a Power Supply is plugged into power, there is a constant 5 Volts present.
The 5 Volt Standby Power.
The ATX power on switch is a Momentary Contact Switch.
Pressing it closes the Soft Power On circuit -> Temporarily.
The 5 Volt Standby power is re-routed, and 'excites' the Power Supply, which turns it on.
THIS type of ATX power on switch is common.
It is inside the plastic Power On button assembly,
http://www.directron.com/atxswitch.html
Regards,
joecoolvette
http://en.wikipedia.org/wiki/Computer_power_supply
http://en.wikipedia.org/wiki/Switched-mode_power_supply
http://www.hardwaresecrets.com/article/181
Apr 07, 2013 | IBM Computers & Internet
IBM T41
is the power supply fan working?
Sep 22, 2008 | BenQ FP731 17" LCD Monitor
Pin connection front panel power switch
The only place to get it is from IBM, as it was designed specifically for them to go in their ThinkCentre A50 line of computers.
The link for the User's Guide, which is what I presume you need, is:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55533
If, instead, you want the Hardware Maintenance Manual, it can be found at:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55532
Finally, if all you desire is the Quick Reference, go to this link:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55534
Now, just to be complete, though I doubt this would do anything to help you, here is the Setup Poster:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55595
Jan 03, 2013 | Lenovo D865gkd Ibm Motherboard Mpga478b
IBM X3400 Server Power Led Blinking and Pressing power SW, Machine not power up.
hi,
Welcome to Fixya
1: Check whether the power switch has any problem 2: Check Ac and DC led on smps is glowing 3: If it glows , probably the planner(Motherboard ) has the problem
Thanks
Nov 23, 2010 | IBM x3400 Server
No power
check your power cable if it works properly. Try to connect it to another switch. Tighten the connector to your computer.
I hope this will help you out. =)
Aug 24, 2009 | IBM E54 15" CRT Monitor
IBM Think Centre M52- doesn't power on
Here is a checklist. Don't just visually inspect, take your hand and press them in.
Make sure that all power connections are seated.
Make sure that all cables are seated.
Make sure you didn't accidentally flip the switch on the back of the power supply. It happens sometimes, I have even done it myself. (not all power supplies have this switch).
If none of that helps. Post back exactly what it is doing.
Does it beep at all?
Do you get anything on the screen?
Can you hear the devices like CD-rom and hard drive spinning?
Mar 11, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
IBM server x346 has problem
The x346 server should have 2 SMPS in the server , Try connecting one power and test and then try the other , incase the smps has some problem such issues ivolve.
Dec 25, 2008 | IBM eServer xSeries 346
Ibm bios problem
ibm i845 bord date & time save nahi hota cell b change kia ha pls solve problem thx
Dec 17, 2008 | IBM (03R0329) Motherboard
Computers & Internet Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
