Question about LG Televison & Video
Whilst watching the TV it made a noise and lost power. No power appears to be getting to the unit. Have tested the power point and it is fine.
  • LG Master
  • 12,061 Answers
This is a classic switchmode power supply, which is shutting down the set to avoid a fire, explosion, or both. This set has developed a problem, that is so severe that the set must be shut down, This set should now, be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" LG, in your case. Now, when you get the information you want, from the "Quote" well, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have original parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
Posted on Oct 15, 2010
I recently purchased a 32''flat screen TV. There is a small white band that runs across the screen. Then starts all over again. Do you know what might cause that? I still get a picture but can see the...
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 16, 2008 | Televison & Video
Why can.t I watch Netflix on my new Tablet it load fine but when put something on to watch it let you watch for 1mon before going into rolls so you cab.t watch ?
Do you have a friend with a name brand tablet that could come over and test if your wifi can handle streaming? If another tablet gets the same results as your tablet it could be a issue with your wifi access point. I don't use Netflix anymore but can you confirm your new tablet has enough processing power to stream video? Can you stream youtube HD videos?
Aug 17, 2014 | Tablets & eReaders
Jvc lt-z32s2 went dead and makes a static sound at back of unit.
check weather the power cord or component at the power supply board get burned.
Oct 02, 2012 | JVC Televison & Video
There's an intermittent high pitched noise from sharp aquos lc32 le600e
Sounds like a transformer or choke that has loose windings and they are resonating, you can pull the back and put small amounts of silicone on those components or replace the power board
Dec 19, 2017 | Televison & Video
Tv made sizzle pop sound and went out
All depending on the models, but i have seen and work on may units with this problem, there are a few large capacitors on the power supply that are sometimes doubly secured with glue, that in turn becomes conductive and causes faults like this. check all the large capacitors for any low or nil readings and with a fine point probe, carefully remove the glue on the and around the caos, and elsewhere if you see any. Good Luck.
Aug 27, 2009 | Apex Digital GB65HD09W 65" Rear Projection...
We were watching a tv program and the tv went black. we cannot get it back on
As a basic troubleshooting technique, technicians first determine if there is high voltage or not upon power up and if there is, if it is sustained high voltage. This basic test can be performed by putting your ear to the back cover of the unit and then turnng on the unit. If you hear a sweeping noise such as that of an air compressor shooting air through a nozzle, it means there is high voltage.
If there is high voltage it it important to determine if the high voltage collapses or not after power up.
If you will et me know results of this test, I can assist you futher.
Apr 29, 2009 | Televison & Video
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
No power, lost power while watching tv
after picture is lost, does the screen remain lighting?
Jan 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Feedback from spekers
suggest,checking pwr point earth,power leads, try a different antenna,unplug any external connections not needed to recieve broardcast,shift position of tv by 3 mtrs. Regards Chook.
Apr 01, 2007 | LG DVD 5253 DVD Player
Televison & Video Logo
64 people viewed this question
Computer Repairing
Computer Repairing
