Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Printer is saying error 49. memory low and will not work
Update new firmware
Posted on Oct 21, 2010
Error 49.38.07
Power off the printer for a minute. Power it on. Do you get the 49 error, does the printer READY? If it comes READY wait a few minutes. No 49 error? start printing, anything. 49 come back? clear the print queue after powering off the printer. Power back on. Do what you did above. No 49 error, it was probably a bad print job in the queue. If it comes back again, you will have to go to www.hp.com/support and answer the questions until you get to the FIRMWARE UPGRADE. Read it carefully and do it.
It's also possible there is a bad network, bad memory or bad formatter.
Jul 08, 2014 | HP Laserjet P3015X Printer
Tip
How To Fix The HP Printer Error 49? The HP printer 49 error is a...
The HP printer 49 error is a result of an internal communication issue where the firm has led to a critical error and the formatter processor has simply aborted its operation. The error also has letters defined as XXXX which refers to the issue of this fault. HP records these messages so that if they have started recognizing a high level of error with the same fault address they can easily focus on making various changes with the firmware or other such parts to help prevent the error from executing on repeated basis. According to HP technical support experts, it is said that the error 49 error is a serious cause of a bad printing command, corrupted data, various invalid operations, firmware, formatter, or even it is possible due to EIO card or memory accessories.
Steps to fix the HP Printer error 49
Step1: Power-Off Phase
    ·Power off the device and then carefully disconnect all the communication cables; Network, USB, or Parallel cable.
    ·Wait at-least for 30 seconds and then turn the device back on. If the error still exists then it is a possible device error. If the error does not go away then it is a symbol of Communication Between the Computer and Network Step2: Managing the printer
      ·Unplug the printer and then carefully remove all the accessories such as EIO cards, memory, extra trays, duplexer (if removable), and envelope feeder.
      ·If the error does not exists after you have powered on the printer, start reinstalling the parts one at a time, by powering off before you go ahead with the installation phase of each part till you find the error cause. Next, the firmware needs to be updated to fix this type of issue. Step3: Further method
        ·If the 49 error is present in the printer after removing possible causes then try a cold reset or NVRAM initialization method first. A cold reset process will further reset every minor stored memory settings such as control panel settings or internal and external jet direct settings. NVRAM is more elusive as well as clears out all the internal memory such as error logs and other possible counters.
        ·If this 49 error continues to exists, it is advised by HP tech support experts to replace the firmware DIMM, if there is one.
        ·Check for a proper service manual for specific 49 errors parts Get in touch with our HP customer support Toll-Free 1-800-213-8289
        department for instant solutions to your issues now! We are always there to help you out for any related HP printer error queries.
on Apr 28, 2017 | Miscellaneous
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
When the printer is booting it is stuck at **************************, when it do comes on it comes with error code Error 49.4c02 Product model: HP Laserjet 4100N
Thank you for contacting FixYa with your printer inquiry.
HP Laser Jet 4100 49.4C02 Error
49.xxxx PRINTER ERROR
Description 49 errors are generally communication errors or file related issues and can usually be resolved by following the steps below:
Action Turn the printer off, and then turn it on again.
If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card (or any third-party devices), if installed.
Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
Turn the printer on. If the 49 error returns, turn the power off, and then unplug the printer. Remove the formatter board.
Check that the parallel I/O board is firmly installed on the formatter board.
Check for any non-HP memory DIMMs. If any extra memory is installed, remove it.
Reconnect the power cord, and turn the power on.
If the 49 error returns, perform a cold reset.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence. If the error code continues to come back, it requires a firmware upgrade.
If the 49 error returns, contact an HP-authorized service or support provider.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 05, 2011 | HP LaserJet 4350 Printer
Error 49 Cycle Power FFF
49 errors are possibly one of the most difficult to diagnose.
49 Indicates that a firmware error occurred that caused the processor on the formatter to abort an operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or home-grown applications.
On some occasions, the formatter is at fault, but this is usually
indicated by a 79 Service Error.
I see you state a 49FFF? any other letters or digits displayed?
Specifically 49 FFFF can be a problem if the ribbon cable from the DC controller to the interconnector board is not connected. The control panel display will also be dark.
Other 49 FFx errors can be:
NEC firmware chip error - replace the Firmware
Unsupported EDO Memory installed - Remove unsupported RAM
Fuser life test error during Boot cycle - Replace the Formatter
A Large print Job (>800 pages) or complex graphics can cause the device to quit printing. - Simplify the Print Job, lower DPI etc.,
Good luck
May 02, 2010 | HP Color LaserJet 4500 Printer
When I tried to fax the doc.s always the error 49 is showing up and automatically turned off. And it is saying memory is full... what should I do???
Hi, Please try the below steps to resolve error 49: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=lamerica_nsc_carib&taskId=110&prodSeriesId=3442750&prodTypeId=18972&prodSeriesId=3442750&objectID=c01558499 Also woudl like to tell you that the memory errror is caussed when a print cartridge has a missing e-label. Reinstall the print cartridge.Turn off and then turn on the product.If the problem is not solved, replace the cartridge
Mar 25, 2010 | HP LaserJet M1522nf Multifunction Printer...
Error 49.4401
Hi I only know that error 49.
But you can try this it may help
A 49 error is a firmware error, it might be caused by the firmware itself, or by the failure of a printer module.
How to isolate the cause:
- Verify that the problem is not being caused by a specific job, this error can be caused by bad information being sent to the printer.
- Power off and remove any installed EIO devices, (JetDirect Cards, Hard Drives), power on and test.
Cold Reset the printer:
- Power off, remove any optional memory, power on and retest.
- Power off and reseat any memory and firmware modules on the formatter board, power on and test.
- Power off, reseat the formatter board, power on and test.
Check firmware version: on newer machines with flashable firmware upgrade to the latest version. If you are running the latest version reload it, this might fix corrupted firmware. (Some printers have flashable firmware, others use a Firmware DIMM which must be replaced to upgrade.)
If you haven't found the cause yet it's time to start swapping parts:
- Firmware module if it's a DIMM as opposed to being part of the formatter.
- Memory if installed, some printers have to have at least one memory module installed to run, and it must have enough capacity to function, in some cases installing a module that does not meet the minimum requirements of the machine will cause a 49 error
Jan 19, 2010 | HP Color LaserJet 4650DTN Printer
HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Jan 07, 2010 | HP LaserJet M1522n MultiFunction Printer
Low memory. won't send or receive fax. 49 error message.
This is a problem with the formatter board, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years. Al
Oct 16, 2009 | HP LaserJet M1522n MultiFunction Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
370 people viewed this question
Seeker5211
Seeker5211
