MY BEKO MACHINE IS CONSTANTLY FILLING UP WITH WATER AND WHEN THE WASH FINISHES IS STILL FULL OF WATER.iT IS 15MTHS OLD
Probably something blocking the drain, likely to be something left in a pocket like a coin or sweet wrapper (if you have kids). Don't know the ins and outs of this model but should be simple to trace the drain pipe. Some washing machines have an easy access filter point where anything that shouldn't be in the drain get caught. Warning though, you will need to empty the washing machine of water first or you'll flood the floor!
Posted on Oct 15, 2010
Why wont my beko washing machine will not fill up with water when put on a wash cycle what can the problem be
If you are able to select the program and the ON button is accepted but no water then either the water inlet tap is shut off or the water inlet valve is faulty. Need full model number to provide more information.
Sep 04, 2014 | Beko Washing Machines
Have Beko WME7247W Washing Machine problem. On full wash the mc loads water then stops. Timer does not progress. Water does not heat. Drum does not turn. On Spin and Drain cycle pump works but spin does...
I had a similar sort of problem, and finally called a Beko engineer out. The machine was pushed too far back and had either blocked the water pipe, or waste pipe.... can't remember which, but simply pulling the machine out by an inch cured the problem!
Mar 09, 2014 | Beko WME7247W Washing Machine
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
What controls the water cut-off feed during cycles and when dail is set in off position.
There are electronically turned on and shut off water valves that are controlled by a water level sensor which varies based on what load size/water level you need Small, Medium, or Large. So if the valve gets stuck open since it's an old machine, the water will just keep coming in. But let me ask you this? If you turn the house water value on n NOW...will the wash machine just start filling? If so, it means your valve is stuck open so you would need to replace the water valve which is like $50 online. If the house water valve is on, and when you start the washing machine it starts filling, but just keeps on filling...that's probably because your water level sensor is messed up. So you have 2 things to check...is it the washer water valve is stuck open? or is it the water level sensor that isn't sensing when the washer is full so it just keeps filling it.
Dec 21, 2017 | Home
I have a Beko D 2731 FW its about 4 years old and recently it has begun to leave a gritty deposits. I think this may be due to the top spray arm not running as freely as it used to. I would appreciate any...
Here are a few things to check.
* Worn wash impeller (depending on design). Test by placing a glass upright in upper rack with full charge of water in the basin. Run dishwasher for 30 seconds. Glass should fill up. If not, replace wash impeller.
* Debris caught in spray arm holes. Remove spray arm and clean out with water and compressed air.
* Heating element burned out. Check water temp during wash--should read between 130 to 140 F.
* Insufficient water fill in basin. In most models, proper fill level is just up to the heating element. Much less than this will result in poor cleaning.
Hope this helps.
Sep 08, 2009 | Beko Dishwashers
Beko washing machine
hi there.......this problem could be caused by a failed heater element ...if the element is not heating the machine will just wash wash etc...the front panel will have to be removed to check the heater element....if the element is ok...check the heater NTC ( little white plug in the heater element)...if all ok here....then you have a main PCB board failure....
it may be more economic to have beko send an engineer to you...
regards Sir Galahad
Nov 03, 2008 | Beko 24 in. D3421F Free-standing...
Drum filling with water
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Sep 09, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
