Question about Toshiba e-Studio65 Copier
C57 code c57 comes on as soon as you turn on the copier.
    An expert whose answer gotĀ voted for 100 times.
  • 126 Answers
Error C57 is a Communication error between main unit and IPC board.
There are a number of things that could cause this problem from the fuser to an add-on. It could always be the board itself. You should have a service tech. come out and look at the machine for this problem. Having someone look at the machine would be cheaper then to just start replacing items/ units.
Posted on Jan 24, 2009
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
Dec 27, 2013 | Konica Minolta bizhub C450P Laser Printer
I have a color copier sharp MX-450 with error code H4-30. kindly solve it as soon as possible.
Dec 01, 2013 | Office Equipment & Supplies
Error code E000202-001
The error code deals with the scanner unit / scanning lamp. Have you just cleaned the optic's???? Was the problem there before you started to work on it? Dos the scanner lamp turn ON? I the lamp dos not come on, you will need to replace the lamp and the lamp regulator PCB at the same time as a set. Very,very important... They need to be changed as a set. If you have a working parts machine, I would use the parts from the parts copier. Good Luck
Jan 27, 2013 | Canon imageRUNNER 2200
Malfunction detected Code c0500 comes up as soon as copier is turned on. This is a CF2001
open the front door get down on the floor look up at the slant section right side will see a small hole you will not see it standing up get a small, small screwdriver push the button inside the hole to hit the reset switch. if the code comes back replace the FUSING UNIT the hot part. worse case the control board is bad$$$$$$. Do not continue to reset it can catch on fire and that would ruin a perfectly good day.
Sep 02, 2011 | Minolta CF2001 Copier
Have a Candy Tumble dryer which is about 15 years old (model C57). Worked perfectly for all these years but now pilot light goes on and drum does not turn. What could it be?
Hi usually you will need to take the back/front of and you will find a broken belt replace if broken if it's come off put back on. Regards billy
Feb 24, 2011 | Candy Dryers
Our office has a Dialta Di251 and on the screen it says there is a malfunction was detected and the code is C0500. What can be done to fix that? Christina
C0500 is a malfunction code that indicates a problem with the heater in the fusing unit. The fusing unit is the part that gets hot and "fuses" the toner onto the paper. It is located right where the copy comes out of the copier. This could be a false code but that is rare. You most likely will need a service tech out to repair the problem with the fuser.
You can try resetting the code and see if it comes back.
On the right side edge of the control panel there is a sliding adjuster for the lcd screen contrast. In the "slot" where the button slides back and forth there is a small hole. With the machine turned on take a small paper clip or similar object and insert it into the hole and depress a switch that is just inside of this hole. You should see the screen reset. Now keep watching the screen for a small dot that will appear at the left center edge of the screen. As soon as it does press the number 3 on the panel. If everything is done properly you will get a new screen with several options listed. Press the Trouble Reset tab and this will cause the copier to restart. You should get the normal warm up screen you are used to seeing. If the copier warms up, comes to ready and runs copies then you are good to go. If the code comes back it will need service.
Good Luck and Thank You for using Fixya.
Aug 12, 2010 | Konica Minolta DiALTA Di200 Copier
Manual de sony svga vpl-c57
I have the CD projector but i can
Jun 14, 2010 | Sony VPL CS6 Multimedia Projector
How do i resolve error code e007 on canon copier ir2016?
Dear sir; you may try to reset just turn power off and back on, if doesn't work then have go to simulation procedure;
1, press "p" "*" "clear" "*"
2, enter 14 press start
Just try it and let me know, see how does it work.
Dec 18, 2008 | Sharp AR-M350N Copier
Error code 15-380
15-380 means the exposure lamp in the scanner is not being senses.
Open the scanner and see if the lamp comes on.
If not, most likely the lamp has failed.
If it does come on, then the sensor or processor have failed.
Mar 19, 2008 | Xerox DocuColor 12 Printer
Canon pc980
turn power off and then on it
Jan 04, 2008 | Canon PC-980 Color Copier
Toshiba e-Studio65 Copier Logo
112 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
