Question about Bissell 7901-R Clearview Proheat Plus Upright Vacuum
Water and cleaner are not spraying out - Bissell 7901-R Clearview Proheat Plus Upright Vacuum
  • 1,040 Answers
Here is a Link to one of my Tips that should help:
www.fixya.com/support/r6323257-bissel_carpet_cleaner_dispense_water
Good Luck!
Jim
Posted on Oct 15, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
My rug doctor will not spray out water
check your spray jets are not blocked but also check your small pump is working & operating that spray the water out of the nozzles
Sep 01, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
What causes a carpet cleaner to stop spraying water?
Can only think of 2 things - pump or clogged spray nozzles.
Regards,
Dennis
Aug 22, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 1623 sprayed used water from tool
Hi Beverley, you may want to have your machine inspected by a Qualified Technician at one of our Authorized Service Centers.
Here's a quick link to locating an Authorized Service Center in your area. http://www.bissell.com/service-centers/?cid=ccsocial
Jan 26, 2013 | Bissell 1623 Steam Cleaner
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Wont spray the cleaner n water out
check the dial setting. - presoak, off, cleaner, rinse
is cleaner bottle correctly inserted?
is clean water resevoir empty?
is dirty water resevoir full?
these items will prohibit the water/cleaner from coming out.
Mar 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell ProHeat steam cleaner won't spray water. The accessory
Under the plastic under the water tank (its a pain to pull apart to get to it) there is a solenoid that actuates the water between the floor and the tools. This is toast if its not spraying the floor, its simply not reacting to the signal to let it go through to the water side.
Seems to be a common problem with the Bissell Proheats. You can order a new one online for about $12 and try to get to it to replace it yourself (if you can open up the base its obvious which part it is if you just follow the hoses).
Sep 22, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7901-R Clearview Proheat Plus Upright Vacuum Logo
140 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
