Question about Compaq Armada 110 Notebook
Compaq Armada 110 works only, when AC adapter (PSU) is connected. I changed a new battery (refurbished) and now fully charged, but when unplug AC cable power will be lost. It was same behaviour with the old battery, but it was not able to be charged at all.
  • Compaq Master
  • 12,061 Answers
OK, check the connection IN the laptop make sure they are actually making contact and are actually working. Now IF that is all in order, then I suspect, that your Battery Charger/Internal Power Supply, has faulted, the External and Internal supplies are separate, with exception for tap off to battery charger.
I have had this many times in my shop, you can most likely buy the Power supply sub board assembly and replace it.
Below is a service manual that will show you what to do and the part numbers. Most likely Ebay will be your best bet, or go straight to Compaq or Compaq dealer for the spare parts, or use the 'net.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+110
If you don't wish to DIY, then please get a "Quote" from a Compaq repair Centre
Posted on Oct 15, 2010
My laptop is compaq Armada M700 with Windows XP Professional version 2002, how will i know if my battery is already fully charged? i have been charging it for a day and when I disconnect the charger tha...
From your description it seems the battery hasn't been charged right, so there maybe something wrong with the battery or laptop. First, do a clean to the your Compaq Armada M700 battery and the connection chip on your laptop, then to see if there is something get better. When you charge you laptop, there will be a lights to note the state, do you have noticed? Else if your Compaq laptop battery are used for 2 years please try a new one
Aug 25, 2011 | Compaq Armada M700 Notebook
I have a compaq armada m700 laptop that my dad gave to me as a gift. He said the battery wasn't good anymore but he gave me the power cord and I. Can't seem to turn the laptop on canvsomeone help me.
try pressing the power button down for 5 secs or more,some pc's dont work without the battery fully charged however.
Make sure psu isnt faulty,should "humm"--good luck!
Davey Snake!
Oct 24, 2010 | Computers & Internet
Compaq armada 110 battery not charging at all laptop works on power supply perfectly but when cable removed no charge in battery, new battery purchased same problem how can i resolve please
I'm sorry to here this but in this case you must bring the laptop in the manufacturers service center because they have to replace batt terminals for it to charge them again. It happened to my cousins laptop.
Apr 06, 2010 | Compaq Armada 110 Notebook
How to charge battery in compaq armada e500
You need to connect the power adapter and charge it for some time and check.
May 09, 2009 | Compaq Armada E500 Notebook
Wont turn on
take it back to the place that you bought it. Sounds like you are having a issue with your motherboard.. If you can take it back i highly recommend it. A replacement motherboard could cost a high price depending on what computer you own.
Dec 27, 2008 | Compaq Armada E500 Notebook
Battery does not charge
you may need to get a new one try that ok
Aug 27, 2008 | Compaq CACHE BATTERIES
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Compaq Armada M700
Always start with the simplest solution first so start by cleaning all the contacts, AC adapter laptop plug, laptop socket, laptop battery contacts and battery contacts. How have you confirmed power output from the AC adapter? have you used a voltmeter to ensure you are getting power at the laptop end? Have you used a voltmeter to test the battery? Assuming you have tried all this don't forget that almost any component can interrupt power on some laptops, however you're 2 main culprits with this kind of problem are usually power controller (voltage regulator) and in some cases, on a laptop of this vintage, the charge controller built in to the battery. Try it with a different battery if you have one.
Aug 10, 2007 | Compaq Armada M700 Notebook
Trouble booting up laptop
Goto a radioshack and ask if they can give you a replacement AC adapter for the computer. Bring the computer with you so that they can match it up. If the computer charges and works with the new adapter, it was the plug/adapter that you were using. If it still does not turn on, it may be a problem with the socket for the power adapter and you will need to have a certified repair technician take a look at it
Jul 28, 2007 | Compaq Armada M700 Notebook
Wont recognise battery
Those may have 1 or 2 different problems. Cold Solder joint on Mobo. Bad DC Power Jack. 1: if it is the Cold Solder, you can reflow the solder and be done with it. 2: if it is the DC power jack, It should be replaced. For simplicity lets call them DC(A) and DC(B) There are 3 connections to it. Gnd, DC (A), and DC (B). When the powersupply is plugged in, contacts (A) touch to send +DC to the laptop. (B) is open. When the laptop is using battery power, contacts (B) touch to send power from the battery through the system. Over a period of time (inserting and removing the DC Power Cord), the contacts become fatigued, or oxidized and the DC(B) never closes - so it won't work from DC Battery. RATE ME - if it helps
Nov 26, 2006 | Compaq Refurbished Notebooks: Armada M700...
Compaq Armada 110 Notebook Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
