Question about Cameras
My samsung camera which is purchase from korea model wll series,it's lens did not came out when on the camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 15, 2010
My samsung st700 is brand new have it only a week and it has stopped working. when i turn it on the lens extents and then it stop, i have no screen and it will not respond and then the lens wont retract....
If you have been using this camera outdoors, then the one causing your problem is a grit of sand jamming the lens. Hold your camera with your right hand with the lens facing the ground. Next, tap the camera's base to your left palm while powering on the camera. You might want to do this several times. If it still wont work, and you can avail of the warranty to save repair cost.
Hope this helps.
May 12, 2011 | Samsung DualView ST700 Digital Camera
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
I have been offered a SiGMA 400mm F/5.6 manual lens for a minolta mount. Will it fit my camera? Cheers Pete
Minolta had two lens mounts. One for manual focus SLR film cameras and one for Auto Focus SLR Maxxum film and digital SLR cameras. Sony uses Minolta Maxxum lens mount.
If the Sigma 400 f5.6 lens was made for Minolta X-700 series, XG, series, XD series, SRT series, then it will not fit on your camera.
Jun 17, 2010 | Sony Alpha DSLR-A200K Digital Camera
I love taking wedding photos. do you think the
Yes, I'm sure that camera will be fine, the 20D some years back was considered OK for wedding images
BUT its more about the quality of the LENS you are using and will it wok in all situations
I used to do a lot of Film work for weddings and used various canon camera bodies, but the lenses where the important factor for speed, composition - I also used a top quality flash unit, that could be used OFF camera. I used a 28mm lens, 50mm 1.8 lens - very high quality and cheaply available, 135mm portrait lens, and various zoom lens
I also always used a tripod, so i could compose the groups and then leave, the camera and go and work with setting up the group, and using a remote take the picture. I also used a flash frame on the flash, so I could turn the camera between portrait and landscape with out worrying about the flash gun
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 05, 2010 | Canon EOS 50D 15.1MP Digital SLR Camera...
Lens will not come out when powereing on. Battery is charged.
You are right, the lens is stuck, and it might be a sand in the engine of lens,. Take a part the camera and see the engine. Its not dificult.
Oct 26, 2009 | Samsung Digimax L60 Digital Camera
Problem in my mobile.my mobile series is SGH U 700 sliding model.mobile strip is not working properly.so i want to know samsung service center in salem,coimbatore(tamilnadu)
Today purchased Sigmatel FXD S400. Neither Camera nor Video camera working. Seems software problem or what else could be. Please help me....
Aug 15, 2009 | Samsung Cell Phones
Camera wll not stay on - immediately turns off - tried charging battery and purchasing new battery - not the problem
I wish I knew the model number of your camera. The best I can do is send you to this link. Hope it helps:
http://www.kodak.com/eknec/PageQuerier.jhtml?ncc=au&lcc=&pq-path=10/3905&pq-locale=en_US
Jun 25, 2009 | Kodak Cameras
Minolta 7000 Maxxum
The Minolta Maxxum 7000 uses a Minolta A mount, which is also used on the Sony Alpha series, as they bought out Minolta's technology. All Maxxum lenses should work for the most part on the Sony Alpha series of DSLR's, including the autofocus.
-John
Sep 15, 2008 | Tamron 28-300mm f/3.5-6.3 XR Lens for...
Please help
Hi!
In issues like this it helps to have the camera on my workbench where I can test its bits but from your description the problem is likely the servo motor that moves the lens in and out.
When the motor starts to go bad you can still get it to function by pushing on the lens - as you did - but once it freezes the system will stop to function.
Samsung offers service for that camera - you need to follow this link:
http://www.samsungcamerausa.com/support/
Sign up for a service account and then log in, at which point you can begin the process of initiating a service request and contract. You can do this, but the cost of the repair is likely to be higher than the cost of simply replacing the camera, especially when you factor in the shipping and insurance costs both ways.
Your model camera is available on Amazon for as little as $80 and on EBay can be purchased brand new for as little as $107 thru buy it now auctions. YMMV but I suggest replacing it with a new model.
Nov 15, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
