Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
SHOWING RED MY APEX IS SHOWING RED WRITING ALONG OR RED WITH THE SHOW YOU ARE WATCHING. I CAN GO TO FACTORY SETTING AND GET RID OF IT, BUT SOMEHOW NOW IT WILL NOT DO ANYTHING ON FACTORY SETTING. IF YOU UNPLUG IT AND WAIT, IT WILL GO AWAY, BUT SOON IT WILL COME BACK AND THE FACTORY BUTTON DOES NOT SEEM TO DO ANYTHING. IT IS VERY BOTHERING AND I HAVE NOT WATCHED TV IN DAYS. PLEASE PLEASE HELP
    Novelist:
    Champion:
  • 203 Answers
It sounds to me like you have a convergence problem. Most often when it changes after warming up it is still at the point where no parts may have to be replaced. However you must not use it any more until repaired. The way to fix the set is to unplug it and remove rear cover. Find the large metal heatsink(s) that have convergence ic's mounted to them. Number on ic's usually starts with STK. Then you must get to where the pins of these chips come through the board. Use caution when handling board and mark plugs that have to be unplugged. Anyhow, on the underside of board just resolder all pins of convergence ic's and reassemble set. It's really not that difficult to do but you have to have solder and a soldering iron. Most repair shops will charge 100.00-300.00 to perform this repair so with a few supplies you can save alot. Good luck, Russmann.
Posted on Jun 02, 2008
Use dvd player without remote control
just able to watch the first show of my series dvd. is it somehow possible to watch the other shows of the dvd AmanStino Mouse Pad with Gel Wrist Pad grey9 0 7 8 AmanStino
Nov 30, 2016 | Teac Televison & Video
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
Apex shows blue screen
Reset this TV to its factory settings. Refer its user manual for details.
Jul 27, 2012 | Apex Digital GT2015 20" TV
Red key on screen wont show or change channel
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Jul 14, 2012 | Apex Digital AT2702 27" TV
My K10 screen is showing "card locked" How do I get rid of the Card locked
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 01, 2011 | Photography
I need to know what do if my jensen tv screen goes blue and a red lock has appaired in the top right corner
With my APEX Television, this means that the parental settings have been changed so that the TV will not let me watch certain Television show or movie ratings. Just go into the Tv's menu and look for parental controls. This should require a password to change. I would either suggest passwords 0000 or 1234
(My parental settings were my father's birthday year, so try something like that)
Jun 20, 2011 | Jensen Q2749J 27" TV
Sound
Unplug ur tv,replug an hour later let it reset itself. Go in ur tv menu go to Audio setting go down to reset press the reset display,it will set back to factory setting.Ur sound will return.
Apr 24, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Red rash that shows through in dark scenes. Can't
Might cause magnatic field,form.Try unplug,replug the tv an hour,move it couple inches to the left or right might help.
Dec 20, 2009 | Toshiba 50HP66 50 in. Plasma Television
13 in apex tv
On the remote hold down the (F) function key and press mute.
Jan 01, 2008 | Apex Digital AT1314DV 13 in. TV/DVD Combo
No Picture
As long as you can hook that same cable up to a different TV and get a good picture, you must have somehow damaged the tuner on the APEX - unless the set was mishandled while moving. Those cheaper brands won't take much punishment.
Jan 20, 2007 | Apex Digital AT2008S 20" TV
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
87 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
