Monitor signal says check cable problem: - Computers & Internet
    Novelist:
    Champion:
  • 227 Answers
Video card went bad
Posted on Oct 15, 2010
Check signal cable
This messsage is usually displayed when the Monitor is unable to detect any input signal this can be due to the faulty cables (VGA/HDMI). I suggest you to try to connect a different cable and check if the monitor works. If not then update your video drivers.
Sep 21, 2013 | Samsung SyncMaster 540N 15" LCD Monitor
I have a e machines desktop that will not boot up. I turn it on and the monitor says no signal. I think it might be stuck in hibernation mode. The fans on the tower start but thats about it. If some one...
No Signal means you Display or Monitor is not getting signal from Video Card.
In this case:
1. Check if all the cable are properly plugged in. Check on both monitor and computer back. 2. Check if cable is not broken. 3. Try unplugging cables and plug them back. 4. Try some other monitor or cable. 5. If cables are fine than problem could be with your video card.
As you are getting No Signal that mean your monitor is working fine. Problem is either with cable or video card.
Jul 06, 2011 | Computers & Internet
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
No signal
This problem requires you to test both the monitor and the signal input form you cable tv setup. Set the monitor up on a computer and see if it works properly. If it does then you may have a problem with the signal conversion of the cable tv to the monitor. It also could be a weak signal that drops below the monitors sensitivity levels. Have your cable tv repairman check the signal levels on your lines. Another way to test this is to hook up is with a different monitor to test your setup and see if it works. If after testing you find, the monitor does not work properly, then you need to have it serviced. Hope This Helps.
Mar 12, 2009 | Envision 19" Widescreen Flat Panel LCD...
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Acer monitor lcd
no signal means there is no communication between your monitor and your system unit.check and be sure your monitor signal cable is firmly connected,if nothing happens, try the monitor on your friend's system.if no change then try and replace the monitor signal cable, eyo7 eyoifiok2005@yahoo.com
Feb 28, 2007 | Acer Professional P211 21" CRT Monitor
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
