Question about HP LaserJet 3055 All-In-One Printer
HP 3055 printer giving error Scanner error 5 turn offf printer and re-start printer Hemant Raval (IT Asst.) JMC Projects (I) Ltd. CGP1 - Site Mundra (Kutch) India hraval@jmcprojects.com
4 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
HP 3055’s have a known problem with the formatter board and if your printer is in warranty you should be able to get it repaired free of charge. Call HP to clarify. If not get it to a repair shop for a quote.
Posted on Aug 30, 2009
SOURCE: Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Posted on Sep 04, 2009
puertobori
  • 7733 Answers
SOURCE: i have printer hp laserjet
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Jan 16, 2011
How to solve scanner error 5 in HP LASERJET 3055?
The stepper motor controlling the scan arm is defective. Replace motor or entire unit.
Aug 07, 2014 | HP LaserJet 3055 All-In-One Printer
Please give explanation & soulation hp laser jet 3055 scanner error 6 \r\nWhy this problem are create in our printer
Scanner error #6 = DocOriginFind
Per the service manual here are the steps:
1 - Power Cycle the Machine (I'm sure you've done this already)
2 - Replace the Scanner Assembly (After replacing this if the message still appears then.. )
3 - Replace the Formatter and Line Interface Unit (LIU)
Oct 20, 2010 | HP LaserJet 3055 All-In-One Printer
HP All-in-One 3055 "Scanning Error 6" What can we do?
Hi Cherylanne, Give this a try: Scanner Error 6 Turn off then on
1. Clean Glass Scanner Bed.
  • If the glass scanner bed is too dirty or smeared with fingerprints and such, you may get this error. It will not clear itself simply by turning off and on the printer such as the message suggests. Even a build up of dust can cause this. It is triggering a reaction caused by a sensor in the scanner. If you clean it good and then power cycle it, the problem should go away. THIS PROCEDURE FIXED THE PROBLEM FOR THE AUTHOR.
2. Try the NVRAM INITZ reset procedure. REF
  • switch off the printer, then remove all cables connecting to the printer but just the power cable.
  • then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
  • continue holding the button till you see "perment storage init" displayed and releas the button.
  • then at a given point of time the printer will ask you to change laguage,time,date etc.
3. Remove paper scrap or dust obstructing scanner or sensor. REF
4. Clean sensor / remove the glass and clean the bulb and mirrors. REF
  • turn off power
  • remove ADF and inspect blew out any dust
  • unclipped control panel cover and removed top platen cover 4 torx screws
  • inspected and dusted (blew out) the scanner
  • put platen cover back again and placed 5 sheets new paper over right side (where scanner is) and turned on came up happy
  • turned off reinstalled ADF (cleaned the white surface first) turned on again
5. Scanner Bulb is not getting to the alignment area.
Information found @
http://wiki.robotz.com/index.php/HP_LaserJet_3055
Regards
Mike
Oct 12, 2010 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
Scaneer error 6 turn off then on
-then press and hold the *(start/symble) and 5 button togather and turn on the printer.
-continue holding the button till you see "perment storage init" displayed and releas the button.
-then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required.
Oct 28, 2009 | HP LaserJet 3055 All-In-One Printer
Scanner Error 6 Turn Off Then On
Dear Sir,
Welcome to Fixya
1.Switch off the printer, then remove all cables connecting to the printer but just the power cable.
2.Then press and hold the *(start/symoble) and 5 button togather and turn on the printer,continue holding the button till you see "perment storage init" displayed and release the button.
3.Then at a given point of time the printer will ask you to change laguage,time,date etc.
I think it deffinately helps.If you have any problem regarding this issue leave a feedback we were happy to assist you
Have a Nice Day!
Oct 03, 2009 | HP LaserJet 3055 All-In-One Printer
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
134 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
