Question about Sony KP-57WS510 57" Rear Projection HDTV
Red line convergence problem on KP-57WS510
Today when I turned on my TV, I now have red ghost images and red lines that streak across the screen. This is true no matter what the source of the signal. At the bottom of the screen any lettering that scrolls across the screen actually shows up also as red letters which curve up instead of travel side to side. I assume I need a service call. What's wrong? I have heard replacing 2 convergence ICs will solve the problem. Is it worth to try?
  • 84 Answers
Yes replacing the ic's should solve it. It worth a try if you want to spend the money
Posted on Jun 15, 2008
Sony KP-57WS510 Red Hue to screen.
Misaligned grey scale adjustment. Do a white balance adjustment, after entering its service mode. Contact the authorized service center of any experienced service technician. http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
Please visit these sites to get some details.
Jun 15, 2017 | Sony KP-57WS510 57" Rear Projection HDTV
Hi, I have a Sony KP-57WS510 57 in. Rear
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Ghosting and bad color, sound is fine.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 15, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Red horizontal lines on the screen
do these appear around the images on the screen? look like a horizontal ghost around the image. if so you have lost horiz.convergence on the red. you might try a auto convergence setup in the menu on most rear proj. tv's if this dosent work then you need to try and find a shop.
Jun 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony projection TV when turned on a solid red line across screen when turned of a flash of red and until the tv is warmed up red ghost letters behind the normal black ones
Hi, you will have to replace the convergence circuit board on this unit. it is failing to calibrate the rgb stream.I'm sensing signal board failure as well.
Mar 08, 2009 | Sony KP-51WS500 51" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Philips rear projection tv prob
You need to replace the conversion ICs. Both of them.
Mar 09, 2008 | Televison & Video
Sony KP-57WS510 57" Rear Projection HDTV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
