Question about Samsung TXG2548 TV
Turning on and off
TV will turn off when volume is pushed on TV and remote. Will come back on when pushed again. Cannot control volume either
  • 2 more comments
  • wawazener Jun 02, 2008
    Unplugging it for 8 hours does not reset it.
    Do you know which ic is causing the problem
    Is it worth while to get this repair or cheaper to buy new onw
  • wawazener Jun 08, 2008
    I really didn't get any help just wild guesses
  • 3,037 Answers
Check your board for any connections that are overlapping or may be touching each other, You may just need a new board, but have a look and see what you find and let me know. You will need to remove the outer panel to do this so let me know if you have any further questions.
good luck
Posted on Jun 02, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 02, 2008
    If you can't fix it yourself, then it won't be worth fixing, better to buy a new one.
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    usually in a situation like this, unless there is any connection problems (which we hope there are, since they are cheaper to fix), then the problem would lie in the control board which is expensive which isn't a wild guess but I try to help a customer like yourself get the cheapest option of fixing the problem. In this case, it won't be cheap and probably not worth it as other problems are prone to come up as a tv ages.
    Sergeant:
    Champion:
  • 256 Answers
Hi
There is processor IC problem please check your TV with any near by service center...
    Genius:
  • 3,587 Answers
Sounds like the control board inside is going weird.
I'd recommend you unplug and let it discharge, for 5 minutes, then try it again.
  • Patrick Michaels
    Patrick Michaels Jun 02, 2008
    ok..got it...i'm assuming that when using the front panel controls, it's the same?
  • Patrick Michaels
    if you are not intending to fixya this yourself, it's much less expensive to recycle that one, and consider a newer model.
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
TV turns on and off by itself. Volume can't be controlled with remote control and if you push volume control on the TV itself it turns the TV off and on.
The font key switch panel is defective - (usually one of the switches has changed resistance) you can unplug the keypad and just use the remote. You can access the kepad thriough the back panel - but to remove the keypad you have to remove the chassis. Let me know if this helped.
Oct 02, 2009 | Proscan PS60690 60" Rear Projection...
Echostar IR remote (Dish)
to set remote to tv
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Sep 03, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Televison & Video Logo
82 people viewed this question
Henry  Thomas
Henry Thomas
